![]() | Home > Technical (L322) > Where did that cloud of smoke come from? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Thanks Kev, agree |
Could have been. Cleaned up and they might use some PTFE. It's going to a local mechanic tomorrow....we've got so far and I'm advising remotely!
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Any report back from the local mechanic after they had taken a look? 2011 TDV8 Vogue SE |
Time for an update from me.
Did you do a pressure test on that before removing it like Steve Norman ďid for James?
I haven’t had a pressure test on the cooling side if that’s what you mean. I have taken a note of the work James had carried out which caused me to monitor the coolant temperature with the IID which was reporting as correct, however, I still haven’t discounted that this may be an issue and is included in my ever growing list of testing to be carried out once the car is back together. Hopefully your friends vehicle will be a much simpler fix and if it points to the thermostat housing then I may as well change that too |
We will report back soon....we wait until we have the full story to avoid lots of posts... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Changed 4 doughnut rubbers (old ones were fine) as good practice
Good update Rob, lots of familiarity in there for me. I've had to tell the car it's had a new DPF on 2 occasions now due a red light, it's not ideal but at least it gives you a chance. I guess the best thing to do now is run it around and watch how quickly the soot level rises and if a regen gets requested and more importantly, completed. 2011 TDV8 Vogue SE |
Yes. My understanding is roughly 1g per 10miles.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
Rob, just spoken to Steve Norman. He uses a normal (standard pressure gauge) to do a DPF pressure test using the front sensor tube. if it is 2PSI then it is fine. It will normally regen at around 29PSI/2 BAR, but in reality it will do one at 15 psi.
That’s exactly how it was tested with a Sealey pressure gauge on front sensor pipe via a temporary T piece
So far, the work carried out above has cured the amber issue. Ongoing monitoring with IID.
dennij - any updates your end? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
