Home > Technical (L322) > 2010 Heated/Cooled Seat not working
Page 17 of 26 <123 ... 161718 ... 242526>
coopss
Anyone know whether the rear seat heaters use the same parts? 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #576873 21st Dec 2020 7:00pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Re: Climate Seats Fixed
tj2k wrote:
I'd been following this thread with interest (& other similar threads elsewhere) with a view to fixing my seats. I've just bought my car, it has a 3 month warranty and the dealer is covering the faults it had pre-purchase (this being one of them). The problem being that he didn't want me to take it to a dealer to diagnose and fix them because he's underwriting the cost of the warranty himself. I'm not the type to make the job unnecessarily expensive - so I'm working through its issues myself (but I've spent well over a grand now & I've covered the labour myself - which seems wrong!?).
Anyway, I want it sorted so I can just get on & enjoy the car rather than faffing about fixing locks, seats, brakes, the battery etc etc.
So, here's what I found when I finally removed my drivers seat. The ducting of the pelter cell / seat-back motor had indeed, well & truly cracked - with a whole piece having fallen out (which I fished out from below). This art is designed to flex when the seat back is moved. Clearly, over time the plastic starts getting brittle - hence it cracks & breaks apart.
I've now replaced the part, having taken a chance and ordered it from a Land Rover Dealer. It now works perfectly (it's an expensive part & a royal pain to lift the seat out as the seat weighs a tonne). Owing tot he air-bag, I disconnected the battery too (& allowed it to stand 20+mins before disconnecting).
That said, the seat does not *need* to be removed - but it is definitely easier to do if the seat is out of the car.
I'd accidentally cut my hand whilst doing the job (you can imagine the language Censored ) so was bleeding everywhere - consequently, I didn't take many pictures but what I did take - are hopefully good enough:
This is the seat when I first opened it up! See the seat motor ducting!?
This is a closer pic:
Another:
This is the faulty part after it had been removed:
By the way, this is what my car was bleating about before it was fixed:
What did you use to get that fault code please?
Post #577239 26th Dec 2020 1:50pm
Tomc
Northern Ireland 2010 Range Rover Vogue SE TDV8 Barolo Black
Heated seat repaired
Hi all.
After looking through this feed I removed my seat back heat unit. I noticed there was quite a lot of cracking at one end. I decided to try a repair. So mixed some epoxy resin and covered all cracks. When dry I applied some good quality tape for good measure.
I re fitted the unit and to my amazement it worked!!
I must have caught it early enough before any long-term damage was done. Thanks to all.
T
Post #579383 11th Jan 2021 9:59pm
Justin_Sherfy
United States 2012 Range Rover HSE 5.0 V8 Baltic Blue
That’s really cool you were able to fix it. 2012 HSE 5.0 V8
Post #579397 12th Jan 2021 3:27am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Re: Heated seat repaired
Tomc wrote:
Hi all.
T
I had similar experience. It lasted a few months before failing completely. Might be worth keeping an eye out for replacement and grabbing a bargain before you need one.
Post #579637 13th Jan 2021 6:06pm
Tomc
Yeah thinking the same thing tbh.
Cheers. T
Post #579679 13th Jan 2021 11:17pm
KDavies3
United Kingdom 2007 Range Rover Vogue SE TDV8 Barolo Black
Russian Peltier unit fitted and Working
Hi All,
following the failure of my drivers heated seat, I discovered this and many other threads on the subject.
Firstly thanks to all the previous contributors for the help and advice.
Anyway, when I removed my seat back panel (seat removal not necessary as already stated by others).
I found the ducting badly spit and cracked, this I repaired / patched up using a hot glue gun.
I refitted the unit just to try it but still no fan or heat.
Resolving that the Peltier had gone west and being too tight to pay £250 for a new complete unit, I decided to give the Russian Ebay Peltier supplier a go.
My part no. matched one on his list so I thought I'd risk ordering one.
https://www.ebay.co.uk/itm/Peltier-element...2749.l2649
Others had commented that the unit supplied was slightly bigger than the original one.
I can confirm that it is by about 2-3mm in width.
After scratching my head for a bit and avoiding the temptation to try and squash it in, I thought about plastic surgery on the housing.
By this I mean cutting away the sides where foul with the sides of the new Peltier.
You need to cut away the sides on both halves of the Peltier housing.
Hopefully my pictures will make it clear?
As the Peltier is wrapped in a sponge like material I figured it wouldn't leak out to much if at all.
So I set to with a Stanley knife and a Dremel and cut away the sides to allow the fitment of the new Peltier.
So having fitted it into the case (minus the sides) I then sealed the gaps with the trusty hot glue gun.
Spliced in the wires having marked them up first to make sure that they were connected correctly.
The unit was reassembled and fitted back into the seat.
I'm pleased to say that I now have a fully working heated seat.
I haven't tried cooling as it's cold outside.
I really hope this helps others.
I've also recently replaced my Sat Nav antenna and reversing camera (both with generic Ebay replacements about £10 each.
Post #584171 17th Feb 2021 3:35pm
lostinespace
United Kingdom 2009 Range Rover Vogue SE TDV8 Zambezi Silver
Thank you for the write up, really appreciated. Anyone know if I can get the back of the seat in situ for 2009 facelift? 2009 TDV8 3.6
Post #584224 17th Feb 2021 10:16pm
KDavies3
I don't know what the difference is in the 2009 upgrade is is I would imagine it's very similar to mine at 2007.
I followed the guide posted earlier in this thread.
Post #584273 18th Feb 2021 12:28pm
lostinespace
Thanks! 2009 TDV8 3.6
Post #584285 18th Feb 2021 1:02pm
lostinespace
Brilliant thanks for everyone who has contributed just got my heated/cooled seat working on my facelift. Tips for getting the seat back off, the back pulls down once you have squeezed the bottom side tabs out over the metal pole. This is quite tricky I just used a long screwdriver from the bottom by the centre console. I nearly removed the seats after seeing Sam's Motors and Machines video yesterday, glad I didn't. I couldn't get the heater out without a bit more work, I just gaffer taped the 2" split works perfectly.
Fitting the seat back was easier. 2009 TDV8 3.6
Post #596737 7th Jun 2021 3:24pm
jonty88
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
Has the novel repair stood the test of time?
Post #598000 19th Jun 2021 9:37am
lostinespace
Still working cooled seats great in the heat. 2009 TDV8 3.6
Post #598001 19th Jun 2021 9:39am
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Thumbs Up well done i am taking the plunge and ordering two of those heating units from ebay ready for the cold of the winter ! 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #598017 19th Jun 2021 12:04pm
JNC
Have a look on my post in other section.
We have a group buy on full repair kits for these.
Replaces the plastic part too.
Post #598791 25th Jun 2021 8:54pm
