Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 200 |
What did you use to get that fault code please? |
26th Dec 2020 1:50pm |
Tomc Member Since: 15 Oct 2020 Location: Belfast Posts: 37 |
Hi all.
11th Jan 2021 9:59pm |
Justin_Sherfy Member Since: 23 Dec 2019 Location: Washington State Posts: 8 |
That’s really cool you were able to fix it. 2012 HSE 5.0 V8 |
12th Jan 2021 3:27am |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I had similar experience. It lasted a few months before failing completely. Might be worth keeping an eye out for replacement and grabbing a bargain before you need one. |
13th Jan 2021 6:06pm |
Yeah thinking the same thing tbh.
13th Jan 2021 11:17pm |
KDavies3 Member Since: 03 Jun 2020 Location: South Wales Posts: 4 |
17th Feb 2021 3:35pm |
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 |
Thank you for the write up, really appreciated. Anyone know if I can get the back of the seat in situ for 2009 facelift? 2009 TDV8 3.6 |
17th Feb 2021 10:16pm |
I don't know what the difference is in the 2009 upgrade is is I would imagine it's very similar to mine at 2007.
18th Feb 2021 12:28pm |
Thanks! 2009 TDV8 3.6 |
18th Feb 2021 1:02pm |
Brilliant thanks for everyone who has contributed just got my heated/cooled seat working on my facelift. Tips for getting the seat back off, the back pulls down once you have squeezed the bottom side tabs out over the metal pole. This is quite tricky I just used a long screwdriver from the bottom by the centre console. I nearly removed the seats after seeing Sam's Motors and Machines video yesterday, glad I didn't. I couldn't get the heater out without a bit more work, I just gaffer taped the 2" split works perfectly.
7th Jun 2021 3:24pm |
jonty88 Member Since: 04 May 2021 Location: Derbyshire Posts: 5 |
Has the novel repair stood the test of time? |
19th Jun 2021 9:37am |
Still working cooled seats great in the heat. 2009 TDV8 3.6 |
19th Jun 2021 9:39am |
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 |
well done i am taking the plunge and ordering two of those heating units from ebay ready for the cold of the winter ! 2012 Black 4.4 TDV8
19th Jun 2021 12:04pm |
Have a look on my post in other section.
25th Jun 2021 8:54pm |
