![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Yep! No need to clear codes, back heater units are identical.....just plug & play. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Justin_Sherfy Member Since: 23 Dec 2019 Location: Washington State Posts: 8 ![]() ![]() ![]() |
I moved the passenger seat heater to the driver’s seat, and it works now.
lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59 ![]() ![]() ![]() |
Justin did you remove the seats or just the backs out of interest? I have the same issue, drivers broken passenger works. 2009 TDV8 3.6 |
lostinspace: Has yours got the heated/cooled seats, if not, I believe the set up is somewhat different.
Thanks yes 2009 (201o model year) with cooled/heated seats. The passenger works, the drivers whirrs for 10 seconds then cuts out sadly. 2009 TDV8 3.6 |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
@lostinespace, the seats should be the same setup as the heater filters are meant to be swapped as a service item (but probably never get done!). No need to remove seat, just removal of the back panel. It takes about 40 minutes all-in, but can be a bit fiddly. Best thing to do is just take it slow and gentle, only fiddly thing I had was that the seat valance on the centre console side isn't held in with a tab, but is held in with a screw. If you take your time and do things gently you can get the panel off without removing the screw as the valance will flex enough to allow the panel to slide down and past with a bit of gentle persuasion. |
@Justin, just had another look at my old heater ducting and found an identical split in my duct. It was virtually invisible until I pressed the duct at the exact same spot as in your photo and then the crack appeared. Strange thing is if I block off one end of the duct and blow down the other end I don't seem to get any air coming out of the split. |
I did not remove the seats. I pushed them all the way forward and leaned the seat back as far forward as possible. Then, I sat in the luxury of the back seat while replacing the heater. It’s the most comfortable I’ve ever been doing a repair. ![]() |
@Discotigger. It took me a while to see the split. It is amazing that something so small would make the thermistor fail (if that’s what happened).
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Another B1231-7A [Right seat fluid leak or seal failure]. fixed by replacing the seat back unit.
Hi JNC how much was the cell out of interest? Cheers 2009 TDV8 3.6 |
Downhillerffrr Member Since: 20 Sep 2020 Location: Surrey Posts: 17 ![]() ![]() |
I could probably find out myself but does anyone know if you could replace the front seat back blower unit with one of the blower units from the rear seat base? I bet they are similar. |
The front seat base heater unit differs from the front seat back heater unit so betcha that could be the same for the rear seats?
They seem to be very different in design, but cheap on ebay. Buy one and see if the Peltor cell can be swapped? https://i.ebayimg.com/images/g/kVUAAOSwRLZUD9Dl/s-l1600.jpg https://www.ebay.co.uk/itm/Range-Rover-L32...Swtjlcm55s Do these XF parts fit? Cheap used one here if it works https://www.ebay.ch/itm/09-11-Jaguar-XF-Fr...2749.l2649 2009 TDV8 3.6 |
