![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
Duckworths Land Rover are a site sponsor and always offer good prices for forum members,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Try robin at duckworts LR
Mariusses Member Since: 09 Nov 2020 Location: Berkshire Posts: 20 ![]() ![]() ![]() |
Cheers guys. |
alankesaussie Member Since: 17 Nov 2020 Location: Eastern Victoria Posts: 7 ![]() ![]() ![]() |
Hello to all members,
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
cool thread i just noticed a smell of oil after a run!! so will order o rings and do the job over xmas. if the oil cooler is leaking the dealer can have it back to fix that puppy |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
Changing the O-rings is relatively quick and easy whereas changing the oil cooler gaskets takes much more time and risks getting debris into the unfiltered oil supply to the engine, so great care must be taken. However it appears that if the O-rings have gone then the gaskets may not be far behind. Access for the O-rings is quite good with the cabin air intake removed, which is retained by just 2 nuts. |
Thanks for the replies JayK and Graeme I have replaced the two rear O rings with Viton replacements which was relatively easy with bonnet in the service position and have ordered a new oil cooler as my main go to man who is a guru has stated that the factory cooler unit for some reason almost always fails but when replaced but he has not seen a subsequent failure.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Rather than replace the whole oil cooler, just replace the two internal gaskets. The oil cooler rarely fails, just the gaskets need changing, did that on mine and been perfect since. Will save you a lot of money too, gaskets are around £30 all in but a new oil cooler is a lot more. |
just had my oil cooler replaced. the internal gasket had gone (and been jammed up with some sealant and gone hard at some point by someone). I initially asked for just the O-rings to be replaced but the chap said he would look at the internals first and then make a decision. They can go internally and by the time you've farted about paying for the oil cooler to be removed (unless doing it yourself) its was as cheap to have the lot replaced. |
Sincere thanks,
The oil cooler still has the original part number so hasn't been revised as LR always allocates a new number if a part is revised. This includes the gasket because if a new gasket was in use then the oil cooler would have a new number.
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
As this is quite an old thread I couldn't find any hyperlinks which still work. I ordered 'O' rings from here :-
Paul70, thanks for the link just ordered some job to do over the festive break |
Thanks Jayk69 & paul70 I have installed the Viton O rings and I am still waiting for am opportunity to replace the oil cooler which is still leaking |
