Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 27 of 38 <123 ... 262728 ... 363738>
mjdronfield
Duckworths Land Rover are a site sponsor and always offer good prices for forum members,
If you look for them in the Site Sponsors section, you can ask them for a price under there.
Well recommended.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572329 9th Nov 2020 10:27pm
Try robin at duckworts LR
Robin.Hall@duckworth.co.uk There is nothing that can't be fixed with a hammer😜😜
Post #572330 9th Nov 2020 10:28pm
Mariusses
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Cheers guys.
Post #572331 9th Nov 2020 10:51pm
alankesaussie
Australia 2011 Range Rover Vogue TDV8 Santorini Black
[size=18]As a newcomer my sincere thanks to all those that contributed to this post it has proven to be a collective bonanza of useful and insightful information for which I am a most grateful beneficiary Thumbs Up
Kind Regards
Alan
Australia
Post #573182 17th Nov 2020 11:41am
alankesaussie
Hello to all members,
Re this particular issue I also have a rear engine leak as is well documented in the preceding posts.
I am considering as a pre emptive move to replace the two O-Rings with Viton types at the rear of the engine and to do the oil cooler gaskets as well given that removal of same provides easier access to complete the primary O-Ring job itself.
My vehicle has just clocked over 133,000Kms so it may constitute a cheap insurance investment ?
I have 2011 RR full size Vogue 4.4Ltr TDV8 diesel
Any thoughts welcome
Best regards
Alan
Australia
Post #573183 17th Nov 2020 11:53am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
cool thread i just noticed a smell of oil after a run!! so will order o rings and do the job over xmas. if the oil cooler is leaking the dealer can have it back to fix that puppy Thumbs Up 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #575173 5th Dec 2020 7:00pm
GraemeS
Changing the O-rings is relatively quick and easy whereas changing the oil cooler gaskets takes much more time and risks getting debris into the unfiltered oil supply to the engine, so great care must be taken. However it appears that if the O-rings have gone then the gaskets may not be far behind.
Access for the O-rings is quite good with the cabin air intake removed, which is retained by just 2 nuts.
Post #575198 5th Dec 2020 9:39pm
alankesaussie
Thanks for the replies JayK and Graeme I have replaced the two rear O rings with Viton replacements which was relatively easy with bonnet in the service position and have ordered a new oil cooler as my main go to man who is a guru has stated that the factory cooler unit for some reason almost always fails but when replaced but he has not seen a subsequent failure.
The factory may have implemented an engineering upgrade to this component ?
There are a couple of good after market brands but stay well clear of cheap chinese copies[size=18]
[/size]
Best Regards
Alan
Post #575202 5th Dec 2020 10:11pm
Discotigger
Rather than replace the whole oil cooler, just replace the two internal gaskets. The oil cooler rarely fails, just the gaskets need changing, did that on mine and been perfect since. Will save you a lot of money too, gaskets are around £30 all in but a new oil cooler is a lot more.
Post #575208 5th Dec 2020 11:20pm
Dolphinboy
just had my oil cooler replaced. the internal gasket had gone (and been jammed up with some sealant and gone hard at some point by someone). I initially asked for just the O-rings to be replaced but the chap said he would look at the internals first and then make a decision. They can go internally and by the time you've farted about paying for the oil cooler to be removed (unless doing it yourself) its was as cheap to have the lot replaced. Thumbs Up
Post #575209 5th Dec 2020 11:40pm
alankesaussie
Sincere thanks,
Dolphinboy and Discotigger I just received the cooler via courier see pics
I will investigarte the repair option as I could take this back if needed
Best regards
Alan
Post #575213 6th Dec 2020 1:04am
GraemeS
The oil cooler still has the original part number so hasn't been revised as LR always allocates a new number if a part is revised. This includes the gasket because if a new gasket was in use then the oil cooler would have a new number.
I used high temperature silicone sealant on the new gaskets that I fitted because I expect the new gaskets would go the same way as the originals. A non-genuine replacement cooler is likely to use non-LR gaskets which may last longer, but may last less time too. If mine fails again then I may try a non-genuine cooler unless LR have revised the gasket part numbers by that time.
Post #575218 6th Dec 2020 9:16am
paul70
As this is quite an old thread I couldn't find any hyperlinks which still work. I ordered 'O' rings from here :-
https://www.ebay.co.uk/itm/Imperial-Viton-...SwkAxcWUWD
(select BS611 8.73mm ID x 1.78mm CS)
So cheap thought I'd get some before I even looked at the job, but sure enough they were clearly leaking.
Not the easiest job when you're only 5ft7, found myself pretty much on my knees on the engine. Relocating the pipe itself is easy, but could have done with a second pair of hands to raise and lower the pipe slightly in order to rotate the flange and so line up the bolt hole. However got there in the end. Top tip on here re using blu-tack in the socket so as to not drop the bolt as that would have been a real pain. Just got to clean all the oil off the engine now and check for further leaks. Ran out of light today.
Post #576267 15th Dec 2020 5:53pm
Jayk69
Paul70, thanks for the link just ordered some job to do over the festive break Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #576274 15th Dec 2020 7:22pm
alankesaussie
Thanks Jayk69 & paul70 I have installed the Viton O rings and I am still waiting for am opportunity to replace the oil cooler which is still leaking Rolling Eyes
Regards Alan
Downunder
Post #576290 15th Dec 2020 9:32pm
