Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 28 of 38 <123 ... 272829 ... 363738>
mpirie
Be sure to keep an eye on the coolant.
If the oil cooler gasket lets go, you can find oil in the coolant and vice-versa.
Mike
Post #576319 16th Dec 2020 9:56am
alankesaussie
Australia 2011 Range Rover Vogue TDV8 Santorini Black
Thanks mpirie
I will monitor same
Regards Alan
Post #576322 16th Dec 2020 11:43am
paul70
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
BAD NEWS!! Big Cry Big Cry
Thought I just had the job of torquing the bolt to correct setting once amazon had delivered my new 1/4" torque wrench (only had a 1/2 torque wrench which doesn't go as low as 10Nm) then clean up.
New torque wrench arrived and low and behold the bolt will not tighten - seems the thread is stripped. (not on the bolt, but on the hole!)
So now the quandary, do I use some method to make good the thread or do I replace the oil cooler.
Paul.
Post #576326 16th Dec 2020 12:39pm
paul70
Going with ordering a new oil cooler as going to have to remove anyway to make thread good. Might then refurb the old as a spare.
Paul.
Post #576384 16th Dec 2020 7:44pm
Dolphinboy
Oil coolers should come in c. £360 + vat.
Post #576395 16th Dec 2020 8:36pm
paul70
Ouch £360+vat
Going for a non genuine for now from our site sponsor Advanced Factors for £147 next day delivery using discount code on this forum.
Nissens part, possibly not the best but clearly the LR isn't the best either as so many fail! They come with 2 years warranty too.
I might be able to do something with the old one just don't want to be stuck with no options over the Christmas period.
Post #576464 17th Dec 2020 7:28pm
Dolphinboy
Sorry £306 + Vat
Post #576472 17th Dec 2020 8:53pm
Jayk69
Paul70 is this the one you have ordered?
https://bearmach.com/oil-cooler-and-filter...-lr022895a
have my new O rings so will look it over while i replace them 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #576490 18th Dec 2020 8:34am
paul70
Certainly looks to be the same one. I ordered from :-
https://www.advancedfactors.co.uk/lr022895...8142-p.asp
£145 plus whatever postage you go for. I went for DHL next day. But there is even a free option if you're in no hurry. Only ordered 4pm yesterday and it should be with me today according to message from DHL. The discount I found on this forum pretty much paid for the postage.
https://www.fullfatrr.com/forum/topic48279.html
Post #576505 18th Dec 2020 10:44am
paul70
Arrived already!! That's what I call good service!!
Post #576510 18th Dec 2020 11:38am
Baltic Blue
Does it include the bottom gasket ??
Post #576512 18th Dec 2020 12:20pm
paul70
Yes Mike, that came with it.
Paul.
Post #576523 18th Dec 2020 1:41pm
DrRob
Paul Redding at AF is a top man Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #576528 18th Dec 2020 2:44pm
Blitzsah
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
Brilliant thread, some really good pictures and explanation!
I’ve noticed mine has the tell tale signs that the oil cooler gasket is leaking, so will replace this and tube in the back.
That link for the oil cooler says product not found, has anyone got another link?
Cheers,
Steve
Post #576949 22nd Dec 2020 12:24pm
kevinp
The link on jayk69 works.
Post #576957 22nd Dec 2020 12:51pm
