Home > Technical (L405) > front knuckle cracking
Page 1 of 47 123 ... 454647>
Brid91
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I own a 2015 Vogue with 51k on the clock. I was backing my car off the drive the other day when my front offside knuckle where it joins the top arm exploded with a bang (see photos).
I wonder if anyone else had experienced the same?
I am lucky as my previous journey was on a motorway which would have resulted in the complete collapse of the wheel assembly and cause an extremely serious accident.
I am fighting with JLR to pay for the replacement as the technical report carried out by my Warranty provider have stated it is corrosion of the joint. Corrosion isn't covered by my Premium policy hence my fight with JLR.
Surely a vehicle with this capability for rugged use should have such a fundamental flaw with these critical components.
Please let me know if you have experienced or heard of similar happenings.
Post #558846 24th Jun 2020 3:15pm
Here are the photos:
Post #558847 24th Jun 2020 3:25pm
Brid91
Thanks Joe Very Happy
Post #558848 24th Jun 2020 3:28pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Did you have any symptoms/clunking before the explosion? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #558850 24th Jun 2020 3:35pm
Brid91
No nothing whatsoever. There was no clue at all. I think I am very lucky that it happened on the drive. The bang was loud enough for neighbours across the road to hear it whilst in their houses!
Post #558851 24th Jun 2020 3:38pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
If it was me, I'd be getting an independent engineers report and then dealing through the media and if necessary, court. This looks to be a potentially lethal situation, maybe JLR should be recalling vehicles to inspect / repair to prevent serious injury.
I have done something similar with Ford and Renault in my past and in both cases ended up being paid out, Ford buckled before court Renault picked up the court fees as well.
It's sort of thing that really annoys me with JLR, they have a potentially world beating product let down badly by build quality issues and short cuts.
Good luck. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #558856 24th Jun 2020 3:54pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Before commenting further I would like to see better photographs of both sides of the break. It is possible that an earlier crack allowed corrosion to weaken the part causing the eventual complete break.
Its probably worth fighting over, (get a second engineers report) as a new knuckle is about £900 retail. Shocked (does come complete with new wheel bearing and hub though).
Post #558858 24th Jun 2020 4:16pm
AJGalaxy2012
Would you not agree that 5 years and 51,000 miles is early failure, a part like this should last a lot longer? BMW i3 Electric Car
Post #558859 24th Jun 2020 4:36pm
That’s a bad fail. Not heard of it happening before though. So it would appear to be an uncommon occurrence..... There is nothing that can't be fixed with a hammer😜😜
Post #558860 24th Jun 2020 4:37pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I’d be more annoyed at the extended warranty provider who don’t seem to be receiving any flack for taking your money and then excluding this from cover.
Post #558861 24th Jun 2020 4:40pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Possibly think of contacting dvsa they may judge whether a recall is necessary for the early failure of a key component.. if nothing else suggestion of doing this may prompt a better response from JLR 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #558864 24th Jun 2020 4:51pm
It’s a Major failure, not just a ball joint going south.
I wonder if it could be down to galvanic corrosion between the aluminium knuckle and steel pin in the ball joint? There is nothing that can't be fixed with a hammer😜😜
Post #558866 24th Jun 2020 4:54pm
AJGalaxy2012
'Worm', 'Open', 'Can'.......Worms everywhere!
I would think JLR would not want this to go to the authorities and may make the appropriate recompense if appropriate pressure was brought to bear. BMW i3 Electric Car
Post #558869 24th Jun 2020 5:02pm
Fifth Horseman
Agreed. I should have been clearer that I would be fighting this with the warranty company as it seems as though they are attempting to wriggle out of their obligations. The "abnormal bulge of corrosion" in my experience is not that unusual where there is a gap between dissimilar metals and electrolytic corrosion has taken place.
Post #558909 24th Jun 2020 7:46pm
CS
That is a shocker. Presumably it is impossible to see this problem developing as the break was from the inside? (I assume no side impact on wheel or similar that could have cracked it)
As I wasn't 100% clear what component had failed I googled RR L405 front suspension and found a Youtube film titled "2013 Range Rover suspension highlights" featuring Mike Gallery, who was the chief design engineer. He is now retired, but still volunteers at the Jaguar Daimler Heritage Trust at Gaydon in Warwickshire (perhaps not during the lockdown though).
I wonder if you might be able to make contact with him in some way, one might hope he would take a professional interest in this and while his loyalty to JLR might prevent him taking sides in a dispute, he might be valuable in offering guidance on whether this might need further investigation on other vehicles or a recall.
Might there be mileage in taking matters up with LR Customer Relations too, including escalating within LR? One would have thought they ought to be taking something like this pretty seriously, given safety implications, might they offer a goodwill payment as the car is quite new? Dealer FSH is always helpful in goodwill requests.
Good luck and if possible please post how you get on. Only Range Rovers since 1988
Post #558915 24th Jun 2020 8:11pm
