Home > Technical (L405) > front knuckle cracking |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Here are the photos:
24th Jun 2020 3:25pm |
Brid91 Member Since: 01 May 2019 Location: Rotherham Posts: 13 |
Thanks Joe |
24th Jun 2020 3:28pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Did you have any symptoms/clunking before the explosion? 2014 FF Autobiography 5.0 SC
24th Jun 2020 3:35pm |
No nothing whatsoever. There was no clue at all. I think I am very lucky that it happened on the drive. The bang was loud enough for neighbours across the road to hear it whilst in their houses! |
24th Jun 2020 3:38pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
If it was me, I'd be getting an independent engineers report and then dealing through the media and if necessary, court. This looks to be a potentially lethal situation, maybe JLR should be recalling vehicles to inspect / repair to prevent serious injury.
24th Jun 2020 3:54pm |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 221 |
Before commenting further I would like to see better photographs of both sides of the break. It is possible that an earlier crack allowed corrosion to weaken the part causing the eventual complete break.
24th Jun 2020 4:16pm |
Would you not agree that 5 years and 51,000 miles is early failure, a part like this should last a lot longer? BMW i3 Electric Car
24th Jun 2020 4:36pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
That’s a bad fail. Not heard of it happening before though. So it would appear to be an uncommon occurrence..... There is nothing that can't be fixed with a hammer😜😜
24th Jun 2020 4:37pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
I’d be more annoyed at the extended warranty provider who don’t seem to be receiving any flack for taking your money and then excluding this from cover. |
24th Jun 2020 4:40pm |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Possibly think of contacting dvsa they may judge whether a recall is necessary for the early failure of a key component.. if nothing else suggestion of doing this may prompt a better response from JLR 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
24th Jun 2020 4:51pm |
It’s a Major failure, not just a ball joint going south.
24th Jun 2020 4:54pm |
'Worm', 'Open', 'Can'.......Worms everywhere!
24th Jun 2020 5:02pm |
Agreed. I should have been clearer that I would be fighting this with the warranty company as it seems as though they are attempting to wriggle out of their obligations. The "abnormal bulge of corrosion" in my experience is not that unusual where there is a gap between dissimilar metals and electrolytic corrosion has taken place. |
24th Jun 2020 7:46pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
That is a shocker. Presumably it is impossible to see this problem developing as the break was from the inside? (I assume no side impact on wheel or similar that could have cracked it)
24th Jun 2020 8:11pm |
