![]() | Home > Technical (L405) > front knuckle cracking |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Here are the photos:
Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Brid91 Member Since: 01 May 2019 Location: Rotherham Posts: 13 ![]() ![]() ![]() |
Thanks Joe |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Did you have any symptoms/clunking before the explosion? 2014 FF Autobiography 5.0 SC
No nothing whatsoever. There was no clue at all. I think I am very lucky that it happened on the drive. The bang was loud enough for neighbours across the road to hear it whilst in their houses! |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
If it was me, I'd be getting an independent engineers report and then dealing through the media and if necessary, court. This looks to be a potentially lethal situation, maybe JLR should be recalling vehicles to inspect / repair to prevent serious injury.
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
Before commenting further I would like to see better photographs of both sides of the break. It is possible that an earlier crack allowed corrosion to weaken the part causing the eventual complete break.
Would you not agree that 5 years and 51,000 miles is early failure, a part like this should last a lot longer? BMW i3 Electric Car
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
That’s a bad fail. Not heard of it happening before though. So it would appear to be an uncommon occurrence..... There is nothing that can't be fixed with a hammer😜😜
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
I’d be more annoyed at the extended warranty provider who don’t seem to be receiving any flack for taking your money and then excluding this from cover. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Possibly think of contacting dvsa they may judge whether a recall is necessary for the early failure of a key component.. if nothing else suggestion of doing this may prompt a better response from JLR 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
It’s a Major failure, not just a ball joint going south.
'Worm', 'Open', 'Can'.......Worms everywhere!
Agreed. I should have been clearer that I would be fighting this with the warranty company as it seems as though they are attempting to wriggle out of their obligations. The "abnormal bulge of corrosion" in my experience is not that unusual where there is a gap between dissimilar metals and electrolytic corrosion has taken place. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
That is a shocker. Presumably it is impossible to see this problem developing as the break was from the inside? (I assume no side impact on wheel or similar that could have cracked it)
