Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 23 of 38 <123 ... 222324 ... 363738>
AlanS
United Kingdom 2012 Range Rover Westminster TDV8 Java Black
Try and lift the cooler out level as possible, but it's tricky. I had coolant and oil everywhere though. Have plenty of rags handy and if ur unsure, do an oil change after. I did an oil flush and then changed the oil just incase. Some people have drained the coolant before they remove the cooler. Would be a good idea, but it's another job. Try to remove the plastic pipe that goes into the cooler on the left hand side. It's held on by a metal clip and is about 1 inch across. You may get some coolant out of that. It needs to be removed anyway. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544304 18th Feb 2020 3:28pm
Kevio
Thanks Mike/Alan
Weather is holding so i'm going to attempt some more.
Will hopefully take a few pictures of the cooler
Post #544305 18th Feb 2020 3:54pm
Kevio
is it worth using Hylomar when reassembling?
Post #544306 18th Feb 2020 3:55pm
Kevio
also is Shell Helix Ultra Professional AG 5W-30 ok to top up with? it's £6.87 a litre at ECP?
What is the recommended coolant?
Sorry lots of questions?
Post #544307 18th Feb 2020 3:59pm
AlanS
Pink coolant is all about the same. Check the oil on the shell website. They should have a vehicle check facility. I used Comma ECL5L 5L Ecolife Fully Synthetic 5W30 Motor Oil. Amazon does it for about £35 for 5 litres. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544308 18th Feb 2020 4:12pm
Baltic Blue
For the oil you need Shell AF -L as per the photo, but note the “L” is VERY important.
Post #544312 18th Feb 2020 5:11pm
AlanS
On my first fix I used Hylomar. Don't think it's necessary, but it may be worth it in the long term if your new gaskets start to shrink. Only time will tell that. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544313 18th Feb 2020 5:21pm
Kevio
Thanks for the advice i've ordered some oil/coolant before I actually start it back up.
I took some pictures of the cooler before and after it was off. Looks like it could be the source of my oil leak.
when I took the top pipe off in step 6 there was no coolant but it did drain out of the bottom pipe.
finally got it all back together to realise I had not put the clips back on the top hose in step 6 Doh!
Will have to dismantle tomorrow and clip them back on.
Kevio
Post #544332 18th Feb 2020 7:47pm
AlanS
Well done on the pics. My dread was leaving a pipe off or a plug unconnected!! I put all my nuts etc in labelled bags so I didn't get them muddled up. Bit over kill tho. It's also worth making notes or pics or parts removed/unplugged for reference when it's reassembly time. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544337 18th Feb 2020 8:04pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
I did mine about three weeks ago and approached it like brain surgery. But I think you kinda have to?
Oil leak has 100% stopped, but I still keep checking the drive way and underside as I can’t believe how easy it was.
I was also worried about causing an airlock in the coolant system as I also replaced the expansion tank, but no issues - runs perfectly.
All thanks to knowledge shared in the forum. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #544445 19th Feb 2020 7:12pm
GraemeS
Australia
The part numbers for the gasket and for the complete oil cooler haven't changed therefore the gaskets themselves haven't changed which IMO means that left to themselves the new gaskets will also leak when they get to the same heat-affected state. I used a sealant on the new gaskets.
Post #544462 19th Feb 2020 8:39pm
AlanS
That may be the case, but if they change the compound of the gasket, they don't have to change the part number. The part number would still relate to a certain part that fits in a certain place. I would hope JLR are aware of the issue and have changed the material to a more long lasting one! 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544463 19th Feb 2020 8:44pm
GraemeS
Australia
I've found that LR have always allocated a new number to an improved design or improved material, unlike some other manufacturers that give a totally revised part the same number as the earlier version. The complete oil cooler/filter assembly still has the original part number which indicates to me that the gasket between the 2 halves is the same gasket, even though that gasket has only been available as a spare part for a few years.
Post #544529 20th Feb 2020 9:47am
TDV8John
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Just had my Westie go through its annual service at a local LR Indy where all was fine apart from an oil leak diagnosed as a problem with the oil cooler which needed sorting asap.
"That'll be £1,050 plus Vat allowing for labour and a new oil cooler". Big Cry
Found this thread so with some trepidation got the gaskets and 0-rings for the pipe at the back of the cooler and had a go myself.
I didn't take pics but looked like the gasket between the two parts of the oil cooler had failed right at the back in the middle.
There were some fiddly bits but nothing really too tricky so my sincere thanks for the excellent description above of how to go about tackling it, fantastic resource and a great example of how you need to consider your options before going belly up and handing over a bundle of cash!
Thanks
John
Post #544586 20th Feb 2020 6:49pm
AlanS
Well done. Thus forum gave me enough info and courage to have a go aswell!! 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544587 20th Feb 2020 6:52pm
