Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 24 of 38 <123 ... 232425 ... 363738>
Kevio
United Kingdom 2012 Range Rover Westminster TDV8 Java Black
Finally got the coolant hose done and took the RR for a test drive. There wasnt a big puddle underneath like there had been previously but still a strong smell of hot oil.
What degreasing products would anyone recommend to try and remove the oil from the back of the engine, V valley and underside?
Post #544718 21st Feb 2020 6:27pm
AlanS
Mine kept smoking for a few trips. The oil collects in the V of the block and slowly trickles down. Just wait a couple of weeks and it will be gone. I went round a really sharp bend and got traction control kicking in, then 10 mins later smoke pouring out!! I thought a seal had failed but it was just more oil coming out of the V. It's not easy access to use degreaser. Time will do it better. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544721 21st Feb 2020 7:04pm
mattgage
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
Many thanks to mm289 and others for vital info that enabled me to (almost) sort out my oil cooler / O ring leak. Brilliant.
I say almost because, having carefully completed the job and started the engine AOK with a smug smile, I thought I'd just have a quick check under the engine as it was warming up to ensure all was well, and my bubble was burst on seeing coolant dripping through....
Turns out it is coming from the click connector coolant pipe that connects onto the oil cooler, as in the photos below. It hadn't formed a proper seal and was leaking (and I suspect might have caused a previous slow coolant leak). I removed the seal within the connector which was perished on one side (additional pic). It looks like an 18mm internal diameter seal, and is slightly flattened and a bit more like a seal than an O ring (though maybe because it's been squashed?). Does anyone know what the spec is, or where I can get one?? Would an O ring work?
I've searched online for the connector and can only find links to bulk buy in the US. Thanks, Matt
Post #546457 8th Mar 2020 5:42pm
AlanS
At least it's not an oil leak!! I was suspicious of that connector when I did mine. Seamed to connect too easily and I couldn't feel any O ring or something slide over the male part. Seemed to form a seal tho! 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #546501 9th Mar 2020 8:16am
kevinp
Years ago I bought a selection box of O rings off ebay and have used them numerous times on various cars for such occasions. Might be worth a try.
Post #546510 9th Mar 2020 9:16am
mattgage
Thanks Alan and Kevin. Yes it clicked on perfectly - I guess as little resistance. It was dripping out quite fast once engine running. I've a feeling it's the top of the three-way EGR cooling pipe?? Anyone changed one?
Post #546513 9th Mar 2020 9:54am
GraemeS
Australia
The T-piece with its 3 hoses is LR022718. I'd be looking for a suitable o-ring.
Post #546525 9th Mar 2020 11:30am
mattgage
Many thanks for the confirmation Graeme. Have ordered both...
Post #546536 9th Mar 2020 12:24pm
WdeRave
Spain 2010 Range Rover Vogue TDV8 Santorini Black
Found this surprise ..... Big Cry
And this time it was not the o-rings .....
So got the car towed to the JLR dealer. Only for "checking" what is wrong, they charge € 320,00.
Repair would be at least € 3.000 (including parts & materials) .....
Diagnose was clear (and expected) -> Oil Cooler leaking!
So got online and found an Oil Cooler for just € 85 which came including both gaskets!!!! Moved the car to a workshop of a friend (with all equipment Very Happy ) to perform some DIY Whistle
Last Saturday we decided it was time for a change. Everything came of quick and the progress was good. We did not break anything!
Installing the rings
Installing the gaskets after cleaning the base
So far so good .......
But then, when reinstalling the bolts ...... They broke without even giving it the correct torque
So we had to uninstall and reinstall the Censored thing several times.
The best solution we found is to use new bolts, which did the trick.
During the whole process we ruined the thread of the bolt next to the oil return from the Turbo, which also led to one uninstall and reinstall. Embarassed
After all, we had a nice day working to get it fixed, but it is running perfect again. In the end the costs where € 900 including the towing, cost for the diagnose at the JLR dealer, oil cooler & gaskets, new bolts, oil filter, oil and some labor (the friend does not come free .... ).
Keeping a close look the coming weeks if it stays dry, but for now, I am a happy fullfat"er" again.
The posts on fullfat were extremely helpful and spot-on Thumbs Up Bow down RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
(EGR out, 380HP, 800Nm)
Post #546580 9th Mar 2020 5:27pm
AlanS
Well done on the repair. Very strange having the bolts shear, especially when there's a rubber gasket below. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #546585 9th Mar 2020 5:38pm
WdeRave
That was our "thinking" as well ....
And after the third Twisted Evil we changed to new ones. RR Vogue, 4.4 TDV8, 10/2010, Santorini Black
Post #546590 9th Mar 2020 5:59pm
mattgage
Pretty sure I have now sorted the oil cooler leak - many thanks to wisdom imparted on here which made it possible.
After doing the repair I had a dripping coolant leak from the click connector which attaches to the cooler as below (I think this is the EGR cooler hose). Inside this connector is an O ring - which I have since discovered is a 2.5 x 18mm ring, available from simply bearings for buttons. I don't know what the correct material should be so I got both EPDM and Viton rings, but both seem about right, with EPDM feeling a bit more soft like the existing ring. In any case, I ordered the complete EGR cooler T-piece hose (Part LR022718) for only ~£25 and took the O ring out of that to fit to my existing T-piece. It's stopped leaking now.
I was losing coolant before doing the oil cooler fix and suspect this to be the culprit as the existing O ring was perished. It might therefore be worth also changing this O ring anyway if you have the manifold plenum off to sort the oil cooler. It is just about visible to check for leaks without removing the manifold by looking with a good torch from the front right of the car.
Post #547109 14th Mar 2020 12:54pm
GraemeS
Australia
That o-ring is cooked like the cooler gaskets and the o-rings on the turbo oil feed pipe, so I'd keep the Viton ones with spare oil feed pipe o-rings where they'll be found when next needed. Thanks for the sizing - I'll procure a couple for when mine fails.
Post #547176 14th Mar 2020 9:00pm
Webbie
A bit of advice and guidance please:
So, I have just had a service on my 4.4 TDV8 and the start of an oil leak from the oil cooler has been identified. I have been quoted £967 for parts & labour for supply & fit of a new cooler Sad
Does changing the O ring cure the problem in most cases?
How long should it take to change it cost the o ring at an independent, how much should it cost?
Can anyone recommend and independent for the job Northamptonshire or Leicestershire preferred, or Cambs, Lincolnshire at a push.
Post #547708 20th Mar 2020 1:11pm
AlanS
There's 2 types of oil leak from the cooler. 1 from the O rings as you mentioned, then also a gasket (2 gaskets) failure on the cooler itself. If you go to the top of this topic and follow the comments you will be able to find where to look to see if it's the O ring at the back. If it's O rings, it's a 20 minute job. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #547709 20th Mar 2020 1:20pm
