Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 22 of 38 <123 ... 212223 ... 363738>
DrRob
GGDR wrote:
Thanks Mike, although my secondary turbo isn’t called on that often, manifold temps alone make me wonder about that o-ring the more I think about it. Just think about DPF regeneration temps and bear in mind I am doing that quite regularly.
Greg, Rovertune specifically checked for those O ring leaks at turbo end of pipe for me. Unfortunately the turbo leak was from the main turbo Big Cry
My advice would be to run it out to them in Reading one day for a diagnosis. They might have their customer office area open upstairs by now Thumbs Up
And you can do a DPF run Rolling with laughter Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541963 26th Jan 2020 1:49pm
AlanS
United Kingdom 2012 Range Rover Westminster TDV8 Java Black
FYI.
If anyone is after an aftermarket Oil Cooler for a 4.4 TDV8 in the UK, Malting Off Road near Doncaster do aftermarket ones for £162 Inc Vat. Comes with the bottom gasket and a new oils filter and cap. Great guys to deal with, they also have a service/repairs garage aswell. Not just a parts seller. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #541966 26th Jan 2020 1:55pm
plumajp
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
Are they the same for the l322 and l405?
Post #541969 26th Jan 2020 3:00pm
AlanS
If you have the TDV8 4.4 diesel, they are the same as far as I know. The part number for the L322 is LR022895. They said the fit these 90% of the time and never had a return or an issue. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #541971 26th Jan 2020 3:04pm
mattgage
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
Thanks for this - I have the oil weep on a 2012 TDV8. Just wondering whether it’s best to fit this whole unit - or just the new gaskets back onto to the original parts? Does it make fitting that much easier to change out the whole thing? Matt
Post #542117 28th Jan 2020 7:36am
DrRob
My mechanic mate who did mine always fit entire new unit and gaskets. I was happy with that. Some folks just do gasket. Personal choice dependent on bank balance Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542120 28th Jan 2020 8:06am
AlanS
The gasket change is easy enough. A few more bolts to undo. You have an extra surface to clean. Not much extra work and it's only simple. Easy to do once you have the oil cooler out. One piece of advice, be careful when you put the pipe with the two O rings back in. I cracked the cast aluminium part that the pipe goes into. Hence the new oil cooler. Also, there's a coolant pipe that runs from a fitting the the donut shaped air intake pipes and goes to a rubber hose at the front of the vehicle. The fitting that Recieved the small stuff pipe into the large rubber pipe is VERY brittle. It's £80 for a new part so be careful. Don't ask me how I found it was brittle. Sigh. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #542122 28th Jan 2020 8:50am
mattgage
Great intel - thank you very much!
Post #542123 28th Jan 2020 8:58am
plumajp
So can anyone confirm if the 8.73/1.78mm viton O rings fit without leaks????
I'm about to order a pair and dont know whether to go for 9x1.8mm or 8.73x1.78mm
Post #543282 6th Feb 2020 9:54pm
AlanS
Lots of people fit the smaller ones and get on ok with no leaks. If I was you, I would get the slightly larger ones. They will still fit ok. Just lube them well and take care sliding them in nice and straight. The difference between the 2 you mention is very small. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #543289 6th Feb 2020 11:22pm
plumajp
Cheers alan
Post #543303 7th Feb 2020 7:40am
Kevio
Phase 1 is complete following mm289's guide. i.e. i have the intake manifold off. Rain stopped play but i'm hopeful it will pass,
So far i have a couple of questions for you much more experienced owners.
Is it normal to see some oil around when i took the air intake hose off?
Also I had a look in the coolant tank to see if there was any oil to bee seen but the level seems really low. should i see a max line on the tank?
My leak had become worse and the oil level is saying add 1.5 litres i'm hoping I dont find anything more terminal as i continue to replace the gaskets/o rings.
Your thoughts are appreciated.
Kevio
Post #544297 18th Feb 2020 1:22pm
AlanS
Hello,
My airtake Dohnut shaped pipe work has thick gunky oil deposits. Naturally I cleaned most of that off. Don't worry about the low coolant unless it's using a lot. If a seal has gone you may loose a little through that. Leaks never get better, only worse so don't worry. O rings and gaskets usually cure the problem. When you're putting the cooler back on, make sure you tighten the bolts nice and evenly, working opposite bolts in turn like wheels studs. Take care when putting the pipe with the o rings back in. Cast aluminium isn't very strong. Also watch the coolant pipe at the front as I mentioned earlier. 2012 L322 4.4 TDV8
2001 P38 2.5 BMW
Post #544300 18th Feb 2020 1:34pm
Kevio
Thanks for the fast reply Alan, and the reassurance. much appreciated. my main concern is making sure i dont get coolant in the engine.
The Sun is out again so i'll do a bit more Very Happy
Post #544302 18th Feb 2020 2:12pm
Baltic Blue
This picture shows where the oil pipe fits into the cooler.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #544303 18th Feb 2020 2:14pm
