![]() | Home > Maintenance & Mods (L322) > Gearbox flush |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
This post has been edited by the site administration team
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
Really ?? Mobil? this isn't the one that ZF and everyone else on here says is right, would you risk it ? |
I'd love to, but it appears my post has been edited by a mod... |
I replaced my own filter at 115k miles, and the filter was still clean ![]() The filter itself is not a particularly fine filter, it is more of a strainer, to catch big lumps of debris from the gearbox. But if there are big lumps of debris inside your box, then an oil change is the least of your worries ![]() I would still (and do) advise the filter should be done at 150k, but its not essential. However, on the FF, it is a ring of bolts to remove and replace, unlike the D3/RRS, which require the engine mounts to be released, and various crossmembers get in the way... The moral of the story is, that the LR service interval on gearbox oil is way, way to long. Stick to the gearbox manufacturers service intervals, and you will be fine ![]() |
mikey is probably correct on the filter change , however for peace of mind Id change my filter the day before .
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
It's the same oil, it's now marketed under the Mobil brand name, instead of Esso... As long as it's the LT71141 it's fine.... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
its ok for the zf6hp box? I thought only the zf lifeguard was the one, so much conflicting info on here |
Sorry, crossed track there.... no that isn't the stuff for your box, the 6 speed uses different oil to the 5 speed.... Pete
im glad I pushed that point , I was just about to pull the trigger on that product and F.u.c.k. up my gearbox!
Comes in a box of 12 litres |
Well according to ZF it is available in 20ltrs part number S671 090 253 but can't find any on Google or eBay....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
ZF lifeguard 6 is the one you want, myele also do the same product but as it is a similar price I would stick with the Zf fluid.
they claim this is good for ZF 6 and 8 speed
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
So, how do you change your gearbox filter the day before you flush it? Doesn't make any sense as you have to drop the oil to change the filter! Far too many owners of these flushing machines tell you "you don't need to change the filter" but imho thats non sensicle! Would you do that to your engine? and no i don't believe for a second, its just a strainer! Else why have it as a serviceable item? You don't change the strainer in your engine sump at service points now do you! ![]() |
