Home > Maintenance & Mods (L322) > Gearbox flush
Page 2 of 11 <123 ... 91011>
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Following a full megaflush on my SC at 75k, the gearbox is noticeably smoother 1,000 miles in so I would personally recommend. 4.2 Supercharged Vogue SE
Post #282734 25th Sep 2014 9:06am
Mikey
nicedayforit wrote:
Given the chances are that by 70-80k your torque convertor lock-up clutch friction plate is probably well worn with the particles from it having been absorbed by the transmission oil making the transmission oil more akin to a grinding paste than good quality oil. In addition microscopic particles of aluminium will be in the oil due to the resulting metal to metal contact adding to the problem.
I seriously doubt the gearbox filter is capable of removing either of these particles with the result these particles are quite happily wearing away your gearbox components while you drive. Smile
The official recommendation from ZF, was a FLUSH (Not an oil change) at 75k miles
This has now been revised to a flush, at anything between 50k-75k miles
As has been stated, a drain and refill replaces 4 litres of oil.
A "Double Flush" replaces 4 litres, which then dilutes with the old oil still in the box. You will be lucky if this method replaces 50% of the old oil.
A Flush is the only way to replace all of the oil in the gearbox and torque convertor, with minimal contamination
I actually flushed an FFRR a few weeks back, 07MY with 55k miles. This is the oil that came out...
Post #282877 25th Sep 2014 9:55pm
Harris
United Kingdom 2006 Range Rover Vogue TDV8 Zermatt Silver
Chuach who did your flush?
Post #282882 25th Sep 2014 10:27pm
Chauch
I used IAWA Classics and 4*4 in Wellingborough, so they should be local to you.... 4.2 Supercharged Vogue SE
Post #282916 26th Sep 2014 7:56am
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
so being new to this TDV8 gboxes (sealed for life?) can the oil be changed in these?
Post #282920 26th Sep 2014 8:57am
ebajema
The sealed for life is not really sealed for life and the official recommendation is 100k miles. The transmission filter and pan are a single unit and the drain plug simply comes out when you turn it, like normal. Then remove the pan/filter unit, replace and refill. Now that is very straightforward (done it a few times on the MY 2006 SC when the cooler ruptured, mixing ATF with coolant).
However there is a lot of ATF that stays "in the system" when you do that. So I used cheap ATF to flush the coolant mix out and that was about 5 dump and fill runs before it was very clear ATF and not "milkshake".
Now doing that with the Lifeguard 6 is a bit expensive. However when you do a filter and dump, you need about 7 liter of Lifeguard (and that is a standard set you can buy from Duckworth and the likes). So that means that some 60% of the ATF is replaced by new, plus a brand new filter. Then the question is, do you need to do another dump and fill after that.
I wouldn't unless the old ATF is really really dirty.
As for the megaflush, if that means that most of the ATF is changed out and the filter is new, that would be even better. I may do that before I ship the 5.0 to Malaysia !!!! MY 2010 5.0 SC Galway green and sand interior!!
Post #282922 26th Sep 2014 9:08am
JST
thank you.
So new sump with filter needed (anyone got MPN) and i guess its std fill procedure? (work it through the gears engine running??)
do it the number of times you feel are required to change majority of fluid or Flush as you see fit.
where is the filler, front of the sump?
Post #282923 26th Sep 2014 9:12am
ebajema
I filled the gearbox with the garden spray bottle first (the type that you pump up) until it starts running from the hole. Then start the engine after closing the plug and run it for a few minutes through the gears. Then open the plug hole and fill till it comes out with running engine. Of course all the safety things in place (in park plus parking brake plus blocks on the wheels).
The garden spray bottles are cheap and work like a charm, even the one I bought in Nigeria did great and I used it several times for the ATF changes I had to do. You will probably find them in any garden materials store. I had a 10 liter unit I seem to remember but don't pin me down on that. I would fill it with 5 liter at a time.
Below is an example and I know Dan from Duckworth also sells the kits.
http://www.lrparts.net/full-automatic-tran...d-oil.html MY 2010 5.0 SC Galway green and sand interior!!
Post #282926 26th Sep 2014 9:22am
JST
cheers.
So which box does the tdv8 10MY have? would you happen to know?
that link is with the built in filter, has anyone tried the separate filter/sump items?
http://www.lrparts.net/automatic-transmiss...ery-4.html
Surely you can just use gravity and a funnel with pipe to fill it rather than garden hose?
Post #282927 26th Sep 2014 9:25am
Mikey
The official recommendation from ZF, the gearbox manufacturer is a flush between 50-75k miles Thumbs Up
Post #283257 28th Sep 2014 8:37am
jst,
Post #283273 28th Sep 2014 9:47am
Just priced the kit to do our new 8 speed Shocked Shocked Shocked Over twice the price of the 6 speed!!!
Post #283291 28th Sep 2014 11:30am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Hi everyone,
anyone know of where i can get my gearbox updated and megaflush done please.
ita a 4.2 SC 07 .
Somewhere near blackburn lancashire
sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #283378 28th Sep 2014 6:51pm
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
if any one decides to have a Megaflush or similar done..
please make sure that they are using the correct OEM oil instead of a 'suitable' substitute..
having done a Megaflush to my previous FF ….i would now instead change filter and do partial flush. replacing oil a couple of times.
over the past 15 years there has always been a 'classic' Mercedes from the 1990-1999 in the garage.
there are hundred of threads on the many Mercedes forums discussing flushes both full and partial.
partial seem to be the chosen path for Merc's ( possibly all auto boxes) as the gearbox specilist have found that the fresh oil over a period of time loosens up the fine film of worn parts that get deposited on the wall etc over many years.
Auto boxes work to micro tolerances and it does not take a lot to block up a valve body etc.
a partial flush and filter change tries to avoid this issue by accepting the fact that the film is dislodged but over a more gradual time period and this content is reduced with each partial flush..
thats the idea(urban myth) any way..
sorry to add to the contention…
raj 2011 4.4 TdV8 Nara Bronze
Post #283453 28th Sep 2014 11:01pm
JST
Stan,
excellent, thank you Cheers
James
Post #283501 29th Sep 2014 10:26am
