![]() | Home > Maintenance & Mods (L322) > Gearbox flush |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
to buy the oil and sump your self its around the £160 mark, so an independent would charge about £250 and then about £100 labour if they are kind and maybe more , so id say £350 to £400 for a single drain and refill , £500 + for a double drain . That's just my un educated guess |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
They do have magnets, but that won't trap the non metallic clutch material as it wears off, there is also aluminium in there as well.... Pete
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
And the filter won't catch that either, as the particles are too small
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 ![]() ![]() ![]() |
So sump and filter change + new oil twice flushed through |
that's what im going to do , only with about 100 miles between the 2 changes, I will do the second one myself as its a simple drain and refill |
Personally, I would have a power flush
is that the one they call the mega death flush, also heard that they don't change your filter, scary
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Pete, looks interesting, I will dig further!
I believe you have been misinformed ![]() The pressures involved are lower than the gearbox produces itself, whilst driving. The flush procedure uses the gearbox oil pump, to push the old oil out. The flushing machine measures the volume of old oil coming out, and automatically replaces it The damage comes in the new oil, acting as a detergent, which cleans the old crap out of the oil galleries, bushes and seals. A normal drain and refill will do exactly the same thing, but issues will not be apparent for a longer period, due to the reduced volume of new oil The official service interval from ZF is a FLUSH every 80-120,000 Km's, or 50-75k miles, and 8 years at the very latest, depending on driving style. It is also advised more frequently if you do a lot of high speed driving, towing, or sporty driving. FWIW, in over 80 gearbox flushes I have done in the last 12 months, I have never had issues with a gearbox afterwards. But, I have refused to flush a few, due to various issues/high mile cars ![]() |
My old box (god rest it's sole) had red ATF in it when I bought the rangie, I drained out as much as I could and refilled it with new, correct oil..
I wouldn't call £40 a big saving... ![]() |
where do you get the 20 ltr tub from, not seeing it on ebay only 1 ltrs |
I appreciate your comments , especially as you appear to do this for a living. Tell how much approx. is a flush? on the ZF you tube video it does not show a flush just a drain and refill |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Ebay item number eBay Item No. 141496578109 |
