Home > Maintenance & Mods (L322) > Gearbox flush
Page 9 of 11 <123 ... 8 91011>
elandri
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Power / mega flush - East Anglia?
OK, I buy the argument that "powerflushing" is best as it changes almost all of the oil whereas even a full double change (ie 14 litres) leaves 13% of the old stuff in there.
I can't find anywhere in Norfolk or Suffolk advertising this service. Anyone know of anyone?
Has anyone used these guys (Dartford) http://www.dakar.co.uk/GearFlush.htm Quoted £668 (includes filter change)
or these: (Brentwood) http://www.mercurycars.co.uk/ - quoted £330 (no filter change).
Or have any other suggestions (i.e. for this service - I have read the whole thread so am aware of the other views!)
Post #327162 11th May 2015 1:05pm
Rangeyman
I certainly wont be paying that kind of money for a flush!I am a tight Yorkshireman after all!!!
Post #327241 11th May 2015 8:51pm
Zirconblue
I was chatting to the parts guy and former tech in my local Land Rover dealership, he was talking me through my car and what goes wrong on them, what's a good idea to change etc.
He recommended changing the gearbox oil obviously, he mentioned the cost of a new gearbox should it fail, obviously that was thousands. However he also mentioned the gearbox repairer they use. The price was about £900ish if you take the gearbox to the repairer, or £1300ish if you take the car to them and they remove/recondition/refit the gearbox for you.
Based on those figures, spending £700 on a flush and oil change seems like a waste of money. May as well just change the oil and if it goes bang several thousand miles later just get the box rebuilt. A recon box with fresh oil is arguably going to be better than an old one with fresh oil in it.
Post #327284 11th May 2015 11:39pm
Mikey
With all respect, the 5 speed boxes are cheaper to repair than the 6speed boxes.
Typical recon/refurb on a 6speed box is best part of £2k...
Post #327314 12th May 2015 6:26am
Zirconblue
Ok, this starts to make more sense now. Smile
Post #327358 12th May 2015 10:15am
Pepi
Full flush in South Yorkshire
Full flush.
There is a independant offering the service in West Woodside. South Yorkshire.
Speak to Andy Eddie the eagle watch out 👀
Post #327361 12th May 2015 10:27am
elandri
Oil change - Quantities / Temperatures
OK, decided I'd just do a change so bought sump/filter and 11 litres of Meyle fluid & headed of to my pal's garage.
Removed sump drain plug - got 3.5/4L.
Removed sump - got 1/1.5L
5L out in total. (From other posts I was expecting 7L).
Was wondering if it was low on fluid till, despite following all the gear cycling procedures to the letter, we couldn't get 5L back in! Any ideas?
Took it for a short drive to get the TC stuff circulating.
The ZF procedure states that the oil must never go above 50C. According to the "Snap-On" analyser that was plugged in we were seeing 90C+. I think I've read that the oil & water cooling are linked so 50 would seem rather low. Can anyone comment on normal operating temperature?
Worms & cans come to mind.....
Post #329764 28th May 2015 11:52am
Mikey
I changed a sump just last week, and that took 6L to refill, though they do usually take 7...
The temperature must not go above 50 degrees when filling the gearbox oil, or checking the level.
If it is checked above this temperature, the fluid level will be too low inside the box
Post #329795 28th May 2015 2:45pm
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
im currently doing a long drain down of my Gearbox sump. I pulled the drain plug some 7 hours ago and its still dripping ( slowly ) Im not using the car next week so im going to leave it dripping to see how much more comes out .
I will post some data if anyone is interested . im also planning to cut open the filter/straining basket to see if it is actually a filter or not and again if anyone wants I will post some pics or info
Post #330110 30th May 2015 10:09pm
Mikey
Post #330215 31st May 2015 1:23pm
apole
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Hi there,
In similar position to you, not sure whether to flush or do the manual change including filter.
In my last car, which had similar box ZF16HP I did it all myself in the end, including filter etc.
Write up here as sure similar procedure, just in case it helps:
http://www.vwaudiforum.co.uk/forum/showthr...oil+change
From what you are saying about temp, I would think the 90 degrees could be coolant temp. You can always double check using say a laser thermometer, not as accurate but gives you an idea.
Found a mobile guy that will do mine for £290 all in, no filter change just a megaflush.
Thinking from past experience to try megaflush this time at 70k as on last car very little on magnets or sump pan at 60k.
Andy
Post #330772 3rd Jun 2015 3:11pm
Temp is for gearbox oil temp, it has a sensor in the box and should be read with a diagnostic tool...
Viper, I'm not too sure but I would be a bit wary of doing a long drain down, if you drain all the oil out of the pump you may cause it to not pump when you refill it, some pumps need priming with oil to make them work, they won't pump air, the oil pump is run from behind the TC so hopefully it will get a feed from it but it is something to be aware of.
Personally I don't think the very small extra amount you will get out, will make much difference... Pete
Post #330781 3rd Jun 2015 3:52pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
I am having a gearbox flush done on my 2007 TDV8 which is on 113k miles on Friday at a place near York. I don't know if the oil has been done before but since I have just bought the car I am doing transfer box, both diffs and gearbox. I will be sending a sample of the old oil off for analysis. I will report my findings.
MC
Post #330795 3rd Jun 2015 4:42pm
Mistercorn
Fluids all changed. Gearbox oil was nowhere near as bad as some. Rear diff was pretty bad and front diff had been changed recently. Transfer box was unremarkable. Gearbox is shifting nicely but I will report back after a cold start. I have a sample and will send it off on Monday.
MC
Post #331168 5th Jun 2015 7:27pm
Pepi
Look at the gear box oil cooler mine was blocked solid
Trans oil was running at 60deg. On the transfer machine the oil pressure was running at just over 2 on the indicator ,which I was told was good.
The pan magnets were almost free of swarf the oil was very dark but not black or smelly. So I recon I have a half decent box dispite it's 120,000 miles.
Because the previous mechanical moron of an owner had blocked the water system up with rad seal trying to stop a failed WaterPump leaking, which cost me a new rad because it had blocked the bottom eight rows essential for the flow to the oil cooler, a new WaterPump and pully and belts. I thought it a good idea to check the gearbox oil cooler. While the gearbox connections were detached. It was a good job I did it was blocked solid!
The Maltings 4x4 guys had one in stock and changed it at the same time as the oil mega flush was being done.
Must say a great service and very knowlegable honest chaps.
I would use them again without question.
Just need to change out the isolator switch which is causing the trans fail safe.
Whilst you are at it. check that the water hose that runs from the header tank to the back plate is not damaged. Mine had been left loose and had been rubbing on the crankshaft pully.
Hope this helps someone out there with their troubles. Eddie the eagle watch out 👀
Post #331202 6th Jun 2015 5:10am
