Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Hi Angela.
15th Feb 2015 3:40pm |
Foxy892 Member Since: 02 Feb 2015 Location: Blackpool Posts: 9 |
Thank you, have calmed down a bit now thankfully!!
16th Feb 2015 12:09am |
I think a few of us have graced Petes drive for one thing and another. He gave me some side steps he didn't want when mine bust. Top bloke 2011 Range Rover Vogue SE 4.4 TDV8
16th Feb 2015 7:53pm |
Yep,
18th Feb 2015 12:17am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8270 |
Was an interesting one.. the inline suppressor on the 5mtr lead had a poor connection, badly soldered wire, heat left on too long and had burnt the PCB.... (done by the supplier not Angela) that got the power going but still no sound... traced to a short in one of the front door speakers, luckily the amp within the Android unit has a cut off and prevented it getting burnt out, left for a few minutes, it started again and now works fine....
18th Feb 2015 1:09am |
Ovaltine Member Since: 24 Mar 2015 Location: Ohio Posts: 4 |
Long-time listener; first-time poster here. What a great source of information and many thanks for taking the plunge so that the rest of us can follow along.
24th Mar 2015 4:56pm |
Main problem with using the standard amp is that it is switched on via a can bus signal, I would imagine the HK uses one as well so can't see it being plug and play unless you keep the old head unit to switch it on and off... some have put it in the glove box in place of the CD changer and just left it to switch on and off with the ignition and this turns on the amps.... Pete
24th Mar 2015 6:24pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^^ Wot he said! Hi ya Pete
24th Mar 2015 10:48pm |
Hi, and thanks for the replies.
25th Mar 2015 2:58pm |
From what I can make out the DSP and Logic 7 systems are almost the same, only the logic 7 has surround sound speakers and all the speakers are of a better quality that the standard DSP system, i.e. DSP is 5.1 and Logic 7 is 7.1.
25th Mar 2015 6:24pm |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 |
Having trouble with erisin not returning emails sent back my TV box as faulty and they stil have it 3 months later
25th Mar 2015 8:05pm |
Cheet22 Member Since: 28 May 2015 Location: Hamilton Posts: 27 |
What a thread, amazing info, thanks all
30th May 2015 6:48am |
Yer a little far from me cheet 1994 softail full stars n stripes custom harley davidson |
30th May 2015 7:18am |
There are AV out plugs on the unit so it should work...
30th May 2015 9:17am |
