![]() | Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
I just did the hillbilly conversion, remove horn from top of jack, angle grind a couple of mill off each side, reolace upside down, roll pin fits a treat, quick waft of spray paint to prevent rust, simples |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Anyone know what to put on the top for an L405? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35461 ![]() ![]() |
here's a pic of the jack, looks like a slit in the top of it,
I saw that in the manual today.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I've used the Merc Sprinter bottle jack to lift mine with the steps deployed (and switched to stay out). There isn't much room to move the jack handle up and down between the step and wheel but it does work. |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Thanks, does it go at an angle and handle exits at gap between tyre and rear of step or does it just go underneath deployed step? |
Between the wheel and the step. Not much of an angle but it works. 2012 5.0L S/C
Ok, got one on order cheers,
I got the adaptor (hard plastic) and drilled a hole to fit but the jack also fits inside the jacking points without cutting off the horns. Not sure if the horns would damage the jacking point rubber inserts but it fits ok. 2012 5.0L S/C
Ordered one of those also now so will have a play and see how it goes
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Fellow FullFatists in France may be interested to know that a cheap alternative to the Sprinter bottle jack (which costs a fortune to have delivered to France by the UK supplier referred to above, link on page 1) is available at a mere 36.90€ from Norauto (with whom I have absolutely no connection whatsoever apart from as a customer, so I hope I’m not contravening the site commercial posting rules!). This is their own-brand N40 model; it is rated at 4 Tonnes and has a similar max jacking height to the Sprinter, at 565mm.
I'm glad I haven't ordered one after reports I've seen on the disco forum of them failing during use |
Mine is purely for emergency wheel changing - heaven forbid! - instead of the flimsy scissor jack provided. I use a proper trolley jack and axle stands for anything else …
But then you lose a cubby hole!
