Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 5 of 10 <12345678910>
Robgosty
I just did the hillbilly conversion, remove horn from top of jack, angle grind a couple of mill off each side, reolace upside down, roll pin fits a treat, quick waft of spray paint to prevent rust, simples Whistle
Post #269293 5th Jul 2014 7:13pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Anyone know what to put on the top for an L405?
Post #269297 5th Jul 2014 8:35pm
here's a pic of the jack, looks like a slit in the top of it,
neat way of getting your spare out though,
Post #269301 5th Jul 2014 8:55pm
Emperor Mong
I saw that in the manual today.
I think the pully thing is an option.
Post #269305 5th Jul 2014 9:24pm
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Has anyone tried this bottle jack/attachment with a FF with the Deployable steps and can confirm it does allow adequate access to lift vehicle ?
Post #282451 23rd Sep 2014 2:14pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
I've used the Merc Sprinter bottle jack to lift mine with the steps deployed (and switched to stay out). There isn't much room to move the jack handle up and down between the step and wheel but it does work. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #282484 23rd Sep 2014 4:40pm
J evro
Thanks, does it go at an angle and handle exits at gap between tyre and rear of step or does it just go underneath deployed step?
Post #282485 23rd Sep 2014 4:51pm
Nomad
Between the wheel and the step. Not much of an angle but it works. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #282486 23rd Sep 2014 4:55pm
J evro
Ok, got one on order cheers,
Just got to decide if I should grind the horns down and leave it or get the adaptor ( which states MIni/BMW is this the correct one still?)
Post #282584 24th Sep 2014 1:27am
Nomad
I got the adaptor (hard plastic) and drilled a hole to fit but the jack also fits inside the jacking points without cutting off the horns. Not sure if the horns would damage the jacking point rubber inserts but it fits ok. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #282602 24th Sep 2014 7:07am
J evro
Ordered one of those also now so will have a play and see how it goes
Thanks Thumbs Up
Post #282711 24th Sep 2014 10:59pm
bebechoon
France
Fellow FullFatists in France may be interested to know that a cheap alternative to the Sprinter bottle jack (which costs a fortune to have delivered to France by the UK supplier referred to above, link on page 1) is available at a mere 36.90€ from Norauto (with whom I have absolutely no connection whatsoever apart from as a customer, so I hope I’m not contravening the site commercial posting rules!). This is their own-brand N40 model; it is rated at 4 Tonnes and has a similar max jacking height to the Sprinter, at 565mm.
I have bought one and am very pleased with it – apart from the jack pumping lever which is a fiddly 3-part affair. I have replaced that with my own design, and have also adapted a rubber jacking block (also from Norauto – 2.60€) to fit the jack head and the FF jacking recess. Happy bunny now! It's "bĂ©bĂ©choon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #296035 30th Nov 2014 10:11am
I'm glad I haven't ordered one after reports I've seen on the disco forum of them failing during use Sad
They are meant only for an emergency tyre change but we all use them a bit more than this,
Hence me choosing a cheap heavy duty 20t model that is barely stretched on use with an ff, disco or other vehicle 😄😄 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296037 30th Nov 2014 10:30am
bebechoon
France
Mine is purely for emergency wheel changing - heaven forbid! - instead of the flimsy scissor jack provided. I use a proper trolley jack and axle stands for anything else …
The bottle jack fits a treat in the deep “removable stowage box” (see pic below), and the jack raising lever fits in the same space as the warning triangle. Perfik.
Previous:
Disco II
Post #296046 30th Nov 2014 11:31am
But then you lose a cubby hole!
Heaven forbid!
Instead I carry a small piece of plastic with The AA stamped on it Smile makes life so much easier lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296182 30th Nov 2014 9:23pm
