Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7775 |
In theory that would work......... this is as far as we seem to have gone practically, as I don't think anyone has actually tried it.
5th Nov 2014 4:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
i've moved your other post to 'group buys' Paul.. ... - .- -.
7th Nov 2014 8:40am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Right as promised I have been thinking about this linking in to the factory harness and not cutting any wire problem, and I think I've got it
8th Nov 2014 11:53pm |
Just seen that I've replied to the earlier post in Group Buys here OOPS! But as it concerns the install side I suppose that this is the right place to rumble on Yesterday I couldn't spell Engineer... Today I are one!
8th Nov 2014 11:58pm |
Seems to make sense theory wise. Minimal wire cutting if at all..... Just utilises DSP in boot as far as existing system, so crossovers intact.
9th Nov 2014 6:41am |
You forgot to say that if your feeding the aux in to the TV socket, it will have to be a 2005 on touch screen system, as the non touch system is only mono on the TV socket, sorry to all of you with an early system, I'm afflicted that way too Yesterday I couldn't spell Engineer... Today I are one!
9th Nov 2014 9:09am |
By the looks of the second picture the only feeds that are missing are +12v and accy +12v, that should be easy to pick up from the wiring in the boot
9th Nov 2014 9:14am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Baris can do the aux in upgrade to the earlier radios, with either intrernal (pins) or external (phonos). .
9th Nov 2014 10:42am |
Are but that's a lot more than the £25 worth of adaptors that I've found Yesterday I couldn't spell Engineer... Today I are one!
9th Nov 2014 10:46am |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
So forgive my ignorance, just a little confused now... what would be the advantages of the dsp and bm54 ? Apart from no wire cutting of coarse. Will it generate better sound quality ? For me I just need to be able to use the fbh. Would I need the dsp to do this ? Or will it work with just the remote. |
9th Nov 2014 2:03pm |
You must have different wiring to me the Miggit, as the TV is a stereo feed.....
9th Nov 2014 3:41pm |
Okie dokie |
9th Nov 2014 4:08pm |
mjdronfield, sorry bud, when you said TV socket I thought that you were referring to the white and blue plugs on the TV tuner box, what you are referring to is the 40 pin plug.
9th Nov 2014 4:20pm |
Now...... I..... Don't ...... Want ........to make ...... things......difficult......
9th Nov 2014 4:29pm |
