![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I've already done away with the CD changer and replaced it with a Grom BT3, the Head unit still thinks its a CD!
Right, so can you still get the CD channel on the old head unit? If so my cunning plan will work using the cd wiring! Yesterday I couldn't spell Engineer... Today I are one!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
On page 6 of this thread, magu posted this and asked if it would work.....
That is a digital to analogue converter for use with Logic 7 systems. You still need the base unit like the BT3 that I fitted
Ah, ok. Didn't want to have given out dud info......
No probs Bud |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
/normal_2013-01-08%2012%2001%2032~0.jpg[/img]
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
Which was ??? |
Baris Member Since: 06 Mar 2012 Location: North London Posts: 95 ![]() |
Good stuff guys. Never thought a screen would fit in the glove box lol.
Many thanks Baris.
Benjamin Member Since: 11 Oct 2014 Location: Surrey Posts: 7 ![]() ![]() ![]() |
You don't want to use the TV input, for the following reasons.
TV audio only mono ? .
Agreed. Purely for the fact that the tv doesn't come back on when you re start your car. So the thought of having to lean over to select tv option from the glove box,every time you get in the car, is an unnecessary chore. Why do you prefer to use the tv input rather than the aux input? Did you want to keep it as a separate input? barisahan@gmail.com |
I was just thinking of those people without the AUX in mod on their BM54, ie without the female RCA phono plugs or the 3.5mm jack plug like you fitted to mine.
