![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
In theory that would work......... this is as far as we seem to have gone practically, as I don't think anyone has actually tried it.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35514 ![]() ![]() |
i've moved your other post to 'group buys' Paul.. ... - .- -.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Right as promised I have been thinking about this linking in to the factory harness and not cutting any wire problem, and |
Just seen that I've replied to the earlier post in Group Buys here OOPS! But as it concerns the install side I suppose that this is the right place to rumble on |
Seems to make sense theory wise. Minimal wire cutting if at all..... Just utilises DSP in boot as far as existing system, so crossovers intact.
You forgot to say that if your feeding the aux in to the TV socket, it will have to be a 2005 on touch screen system, as the non touch system is only mono on the TV socket, sorry to all of you with an early system, I'm afflicted that way too |
By the looks of the second picture the only feeds that are missing are +12v and accy +12v, that should be easy to pick up from the wiring in the boot |
Baris can do the aux in upgrade to the earlier radios, with either intrernal (pins) or external (phonos). .
Are but that's a lot more than the £25 worth of adaptors that I've found |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
So forgive my ignorance, just a little confused now... |
You must have different wiring to me the Miggit, as the TV is a stereo feed.....
Okie dokie |
mjdronfield, sorry bud, when you said TV socket I thought that you were referring to the white and blue plugs on the TV tuner box, what you are referring to is the 40 pin plug.
Now...... I..... Don't ...... Want ........to make ...... things......difficult......
