Home > In Car Electronics (L322) > Dash camera fitment
Page 4 of 8 <12345678>
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Like it - Thumbs Up
How do you do that then? "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #255673 23rd Apr 2014 9:14am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Mr P, I asked Tobi@s to sort it out on this forum
http://forum.dashcamtalk.com/threads/mini0...96/page-17
I had to rename the firmware and then place it on the route of the sd card, camera then prompts the up grade, re format the card when loaded onto camera. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #255704 23rd Apr 2014 12:04pm
ksmith100
Scotland 2005 Range Rover Vogue 4.4 V8 Java Black
As much as I hate to be a party pooper, I dont like people being in trouble with the law either, so when picking a dashboard cam please remember this when choosing a camera -
The Road Vehicles (Construction and Use) Regulations 1986
Television sets
109. (1) No person shall drive, or cause or permit to be driven, a motor vehicle on a road, if the driver is in such a position as to be able to see, whether directly or by reflection, a television receiving apparatus or other cinematographic apparatus used to display anything other than information—
(a) about the state of the vehicle or its equipment;
(b) about the location of the vehicle and the road on which it is located;
(c) to assist the driver to see the road adjacent to the vehicle; or
(d) to assist the driver to reach his destination.
(2) In this regulation “television receiving apparatus” means any cathode ray tube carried on a vehicle and on which there can be displayed an image derived from a television broadcast, a recording or a camera or computer. You are either at Le Mans or waiting for Le Mans
RSW MKIII V2 All Comms in Central Scotland
Post #258274 8th May 2014 3:02pm
Hmmmm 109. 1. c seems to fit nicely with a dashcam display ? - "to see the road adjacent to the vehicle" .
Post #258291 8th May 2014 4:55pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
"Cathode Ray" do even TV's have these anymore! There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #258292 8th May 2014 5:01pm
ksmith100
Not seen a cathode ray tube for years. Yes I know the law may be a bit imperfect, but it only takes one plod having a bad day to find yourself in a bit of bother, and as it stands it could be enforced with regards to cameras with screens. You are either at Le Mans or waiting for Le Mans
Post #258293 8th May 2014 5:07pm
^ + ^ + ^ , my thoughts exactly.. ... - .- -.
Post #258295 8th May 2014 5:20pm
Welshdragon
Well thankfully my camara's screen goes blank in less than a 1 min after turning the ignition switch on. Mr. Green If it dont work.......burn it!
Post #258303 8th May 2014 6:02pm
ksmith100
That's you sorted then Welshdragon Smile Mine has no screen at all, so no room for misinterpretation. There are so many of these cameras on the market now that have screens, and not everyone knows the law. The wording of the law is not accurate, however it does apply. Like I say it only takes one plod who's had a bad day and he spots your camera, sees the screen and decides he needs to put the world to right and use you as an example. Most plod probably wouldn't bother, to mush hassle but there is always one.
Sorry Joe90, "to see the road adjacent to the vehicle" I don't think that would work, most cameras have a viewing angle of approx 170 degrees, most peoples field of vision is greater, plus you can turn you head and look out the side windows. I am not trying to be awkward or anything, it's how the law would probably see it. You are either at Le Mans or waiting for Le Mans
Post #258372 9th May 2014 7:45am
cucos
Canada 2013 Range Rover Vogue SE 5.0 V8 Indus Silver
I'm interested in getting one of these too... but i believe (could be wrong) that to hold any weight in court they have to also measure your speed, acceleration, and probably some other nonsense too that the cheaper ones do not..
I was looking at a blackvue too, but at nearly £200 there are other things i'd rather spend that on usually.
http://www.szswill.com - seems good, anyone using?
Post #264013 8th Jun 2014 3:07pm
Prop
Save yourself a heap of cash and get one of these. I have 2 of the previous 0801's and they are great. Have GPS and measure G-Force telemetry.
https://joovuu.com/gb/home/106-mini-0803.html
Post #264014 8th Jun 2014 3:11pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
Hard wiring a dash cam.
I intend to hard wire fit a dash cam to my vehicle , but once again my owners hand book bares no relation whats so ever to the actual fitment of the fuses. What I'm trying to find is a fuse that is permanently live even when the vehicle has shut down and gone to sleep. Does anyone know off hand what fuse no would suit my purpose or indeed a list of the vehicle respective fuses.
Your help would be very much appreciated for every time I try fuse by fuse I seem to Confused wake the vehicle up. Confused
2010 TDV8. Thumbs Up
Post #266069 18th Jun 2014 10:49am
ebajema
I would argue that 1.b. is applicable as well and I bet a good barrister would argue that point quite easily. I have to still install mine with dual camera (facing front and rear). In my case the screen will be hidden from my view but I understand the point. I have the dual view screen of the FFRR as well and that gets around that law as well but also the multi camera option, showing picture in front, rear and on the sides, obviously complies with the law as those cars are road legal in the UK.
It is when you are watching the recording while driving, you could get in trouble but if you see the real time image I don't see a legal problem Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #266080 18th Jun 2014 12:22pm
Welshdragon
Silversurfer, I already had a fuse tapped into the parrot phone system so piggy backed of this, its the 7th fuse in on top row, see picture for a better look Thumbs Up If it dont work.......burn it!
Post #266099 18th Jun 2014 1:48pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
In fairness I doubt you'd find a cop with enough time to care if your camera has a screen. After all it's only displaying what is on the road ahead so it's not like you'll be watching it like a telly. If you are you may seriously need to get help Laughing 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #266105 18th Jun 2014 2:19pm
