![]() | Home > In Car Electronics (L322) > Dash camera fitment |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
I've fitted the same cam in my FF and it's located up behind the rear view mirror. It does seem to be the best one around at the moment. "On first name terms with my local Dealer......now."
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
I looked at fitting mine on the passenger side as it then pretty much disappears behind the rear view mirror. But I didn't like the idea of not been able to easily access it from the drivers side without having to move the rear view mirror etc.
Trev18, if night video is important then I guess it might be worth waiting for the new version. But what attracted me to the 0801 was the good reviews and so far it has lived upto expectations, and if I'm honest its exceeded them for its daytime video quality.
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Sounds about right a new model out |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
this section on the dashcam site is pretty good , it lists the dashcam and gives a brief review of it,
Up date on the Camera,
there has been problems with the cards on this model, i gather you've read the threads on this..
Mine has been running with out issue since the end of October with a 32gb Samsung type 10 memory card, never had any problems the card filled up and then over writes oldest file as needed so its always basically near enough full.
Stan, the camera picture quality is very good from low very bright sunshine to dark grim days, even the night time, headlights only are good enough for me you can see the road well enough, if there are street lights the quality will be better, no blury picture here on 1080p.
cheers for that.. |
You be upgrading soon then ? |
yep, my crappy 720p jobby will go nto the wifes car and i'll get something a bit better.. |
Just double checked my memory card and its definitely class 10 and has worked flawlessly from 1st Nov 2013. But as you said it does state to avoid class 10. Its what I had sitting around so used it and its never given me any cause to worry. The dashcam has recorded in excess of 135 hours so far and I have it set to record 3minute clips.
Top job Prop |
