![]() | Home > In Car Electronics (L322) > Dash camera fitment |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Like it - |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
Mr P, I asked Tobi@s to sort it out on this forum
Hmmmm 109. 1. c seems to fit nicely with a dashcam display ? - "to see the road adjacent to the vehicle" .
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
"Cathode Ray" do even TV's have these anymore! There is a difference between knowing your sh!t and knowing you're sh!t
ksmith100 Member Since: 20 Apr 2012 Location: Stirling(ish) Posts: 77 ![]() ![]() ![]() |
Not seen a cathode ray tube for years. Yes I know the law may be a bit imperfect, but it only takes one plod having a bad day to find yourself in a bit of bother, and as it stands it could be enforced with regards to cameras with screens. You are either at Le Mans or waiting for Le Mans
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
^ + ^ + ^ , my thoughts exactly.. ... - .- -.
Well thankfully my camara's screen goes blank in less than a 1 min after turning the ignition switch on. |
That's you sorted then Welshdragon |
cucos Member Since: 08 Jun 2014 Location: Toronto Posts: 1 ![]() ![]() ![]() |
I'm interested in getting one of these too... but i believe (could be wrong) that to hold any weight in court they have to also measure your speed, acceleration, and probably some other nonsense too that the cheaper ones do not..
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Save yourself a heap of cash and get one of these. I have 2 of the previous 0801's and they are great. Have GPS and measure G-Force telemetry.
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
I intend to hard wire fit a dash cam to my vehicle , but once again my owners hand book bares no relation whats so ever to the actual fitment of the fuses. What I'm trying to find is a fuse that is permanently live even when the vehicle has shut down and gone to sleep. Does anyone know off hand what fuse no would suit my purpose or indeed a list of the vehicle respective fuses.
I would argue that 1.b. is applicable as well and I bet a good barrister would argue that point quite easily. I have to still install mine with dual camera (facing front and rear). In my case the screen will be hidden from my view but I understand the point. I have the dual view screen of the FFRR as well and that gets around that law as well but also the multi camera option, showing picture in front, rear and on the sides, obviously complies with the law as those cars are road legal in the UK.
Silversurfer, I already had a fuse tapped into the parrot phone system so piggy backed of this, its the 7th fuse in on top row, see picture for a better look |
MachineHead Member Since: 20 Apr 2014 Location: The hoose Posts: 310 ![]() ![]() ![]() |
In fairness I doubt you'd find a cop with enough time to care if your camera has a screen. After all it's only displaying what is on the road ahead so it's not like you'll be watching it like a telly. If you are you may seriously need to get help |
