![]() | Home > In Car Electronics (L322) > Dash camera fitment |
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
Welshdragon thanks for the reply. I did see your excellent post earlier, but alas F7 on my bus is already taken up, and shuts down when the vehicle goes to sleep. However I shall persevere and if push comes to shove I'll come straight of the battery . |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Silversurfer, I am curious as to why you want a permanent live even after the car shuts down. This would mean the dashcam would record permanently and never turn off. This could possibly flatten the car battery during long periods of the car not being used.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
the socket in the rear luggage compartment stays live all the time.. ... - .- -.
The camera is activated by a motion sensor ,and turns itself on and off .and yes the possibility of a flattened battery did cross my mind. I appreciate your thought. |
Thank you for that Mr Moderator. ![]() |
When fitting a dash camera and hard wiring it, what size fuse should I use when using a blade piggy back holder?
3 amp is best.. |
Top man Stan. |
Just check that rear power socket , I think it only stays powered for twenty minutes after ignition off . 2008 MY Supercharged
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I always thought the rear aux was a permanent live. I hope it is, that's what I have my battery trickle charger plugged into! But you've got me thinking now........ 2006 4.2 SC
mine is defo permanant live..... |
CADjockey Member Since: 24 Jun 2014 Location: West Midlands Posts: 19 ![]() ![]() ![]() |
On this general topic, I see that in common parlance 'there's an app for that'... (a few actually)
there's talk about that kinda system here,
blacknwhitemike Member Since: 11 May 2014 Location: Devon Posts: 5 ![]() ![]() ![]() |
Hi guys
