Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 |
Mines horizontal in a small plastic tool box in the boot - not noticed any leakage from it. "On first name terms with my local Dealer......now."
30th Oct 2013 8:22am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35384 |
i've also had mine horizontal for long periods, but i do rotate it 180 degrees every few months and no problems.. ... - .- -.
30th Oct 2013 8:45am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
You don't drill into the jack at all to fit a RangeRover adapter. If you do it will leak.
30th Oct 2013 9:07am |
Thanks all... NDF perhaps my hasty wording. I didn't drill anything on mine but read about someone on the forum doing something that caused a spray or leak of oil
30th Oct 2013 7:54pm |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
just done mine today ,ordered the ali block of ebay got my jack for 10 pounds of a friend ,drilled and fitted new roll pin ,great mod. |
2nd Nov 2013 6:42pm |
Sparkylee Member Since: 15 Apr 2012 Location: Guildford Posts: 85 |
Did you trim alli block or use as it came just drilling it ?
2nd Nov 2013 6:48pm |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
Thank you to all contributors to this thread. I now have a jack fitted with the adaptor.
2nd Nov 2013 7:36pm |
@SparkyLee -
2nd Nov 2013 8:18pm |
Hi yes I'd read that bit and understood the context but the link to the adaptor shows a block with a lot larger base !
2nd Nov 2013 9:24pm |
Picture of my jack after removing the blue horns and with the underside of the BMW adaptor on show to the right of the jack. The shaft hole should be drilled into the centre of the BMW adaptor base face that is on view in my image.
2nd Nov 2013 10:12pm |
Cheers |
2nd Nov 2013 10:29pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Interesting thread. What is the reason for this? Is the existing jack that comes with the car useless / dangerous / flimsy ?? |
3rd Nov 2013 9:04am |
existing scissor jack does work and many have used it but it is very flimsy and really not up to lifting the heavy range..using both of these jacks you should be able to safely replace a wheel on the side of the road for instance.. ... - .- -.
3rd Nov 2013 9:36am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I've just had to use the Land Rover supplied scissor jack as I had a puncture, it collapsed!! Luckily the wheel was still on the car when it happened.
30th Dec 2013 6:46pm |
