Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 2 of 10 <12345678910>
ebajema
If I didn't have a machine shop available, then I would go the grinding down route. But since the shop is there and they always have 1 or 2 apprentices working, I like to give them the practice Smile If I had the machine shop close, I would probably do it myself, just see if I haven't "lost it". MY 2010 5.0 SC Galway green and sand interior!!
Post #185487 29th Apr 2013 12:55pm
supershuttle
I cut off the original top to be flat, then cut a piece of mild steel that fits nicely in the slot on the car. it's getting welded in place today by a mate, I'll pick it up later - he was hopeful that he might be able to top it off with some solid PTFE so when it engages it doesn't damage anything on the car.
I've already tested it with the steel balanced on the top and it works fine, lifts the car a treat.
Pictures and dimensions when I collect it -hopefully this evening Thumbs Up Geoff
Post #185489 29th Apr 2013 1:11pm
ebajema
THanks !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #185491 29th Apr 2013 1:13pm
I wouldn't worry about that SS as the slot it goes into is a hard Rubber/Plastic to protect the sill anyway and easily pops off if you want to replaced it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185497 29th Apr 2013 1:30pm
supershuttle
I don't seem to have the option to upload pictures anymore it started but didn't finish, probably operator error Very Happy but when it comes back I will.
The key dimension is the rectangle viewed from the top should be 30mm x 55mm the 30mm is really tight but you could happily be a bit over on the 55mm - say 57mm maybe. Obviously if you get a measurement from someone who has bought the official BMW bit they would be the ones to use. Thumbs Up Geoff
Post #185526 29th Apr 2013 3:47pm
supershuttle
The finished article, no PTFE just a bit of rubber belting to offset any imperfections Thumbs Up Geoff
Post #185531 29th Apr 2013 4:18pm
^^^ Thats very professional looking. Thumbs Up
For those wanting to make an aluminium adaptor to fit on trolley jack these are some of the dimensions.
The circular disc is 63mm dia and 11mm thick.
The rectangle on the top is also 11mm thick.
Sorry I don't have the dimensions of the rectangle itself but mines buried in the boot at the moment beside the spare wheel, if you had asked yesterday.....
If you wish to fit the adapter on top of a Merc jack you need to drill a 16mm dia hole in the centre of the base, 16mm deep.
You can secure the adapter to the jack using a pin if you wish but I just use mine loose so that I can also use the adapter with a trolly jack.
Post #185605 29th Apr 2013 7:17pm
ahebron
New Zealand
A wee tip to those of you replacing the top of the jack.
Don't press down on the ram without the top being on. It makes one hell of a mess as oil squirts up the side of the ram and all over you. But do not fear as all that has happened is the cup seal has popped out of its outer sleeve. Just pull it back up and try and get all the oil from the wrong side of the seal by using the jack, blowing with an airline or any other way you can think of. I stripped my jack down thinking I had stuffed it but it was all ok.
I made a fitting out of 65mm dia aluminium bar in my mill and lathe. It took far to long but like much machining work was enjoyable.
Adrian VW Amarok 2014 Highline auto
Post #185693 30th Apr 2013 6:46am
ebajema
Thanks guys, exactly what I needed. Will make a drawing and send it to the machine shop Smile
I also like Geoffs solution, simple and looks very workable as well Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #185696 30th Apr 2013 7:02am
For others here are some pre made adapters...
2-4-1
http://www.ebay.co.uk/itm/2X-BMW-MINI-JACK...5af05b8fbf
Black
http://www.ebay.co.uk/itm/BMW-MINI-JACKING...5aeea13eba
Bling
http://www.ebay.co.uk/itm/BMW-MINI-JACK-AD...257b22178c
Normal
http://www.ebay.co.uk/itm/BMW-MINI-JACK-AD...232885a6a2 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #185774 30th Apr 2013 1:42pm
Amazing that a jack adaptor has become a fashion accessory! Shocked Got - 2017 SDV8 Autobiography in Loire Blue
Post #191921 3rd Jun 2013 9:05pm
ebajema
I have the bottle jack and the adapters, one will be for the trolley jack and the second for the bottle jack (I need to drill it still). MY 2010 5.0 SC Galway green and sand interior!!
Post #191933 3rd Jun 2013 9:43pm
J90
France 2006 Range Rover Vogue Td6 Java Black
I've just picked up my 2.5 tonne bottle jack today from Bolton (as per ebay) £20! A great price if you can collect it yourself, he has plenty left. Just thought I'd let everyone know if you are still looking for one.
Ta, Chris.
Post #200258 23rd Jul 2013 2:32pm
Just bought one for my own Range to avoid carrying the trolley Jack:
http://www.ebay.co.uk/itm/2-5-TON-HYDRAULI...7457931773
Post #208292 5th Sep 2013 2:15pm
ebajema
I had to use mine with the original top on it as I haven't changed it yet (lazy bastard indeed) and that worked fine as well, no visible damage to the jacking point. Getting the adaptor fitted is now priority, will do it when the new solenoids for the gearbox are here Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #208317 5th Sep 2013 3:37pm
