Home > Maintenance & Mods (L322) > Damped opening of lower tailgate
Page 5 of 12 <123 456 ... 101112>
M44K TS
The pre-2010MY used to slam down if you let if fall which would risk damaging the cable supports, this just makes it that bit more refined. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #100618 7th Jan 2012 11:42am
Flashman
Definitely going to do this mod, adds a bit of quality to the car that should have been added at the factory. Tom
Current Drive
Previous Drives
Post #100626 7th Jan 2012 12:22pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Maybe Dan could sort out some kits? Cool
http://www.duckworthparts.co.uk/
Post #100628 7th Jan 2012 12:24pm
JustinP
Already done on Page 3 of this thread
duckworthparts wrote:
LR021053 bracket
LR017455 strut
LR017461 strap
£21+VAT for the above lot.
there are few variations in part numbers depending on model years, but as this is being retro fitted i wouldn't worry about it
And if you wanted the screws LR003808 x 2 M6 x 16mm
Post #100632 7th Jan 2012 1:08pm
landyash
2007 Range Rover Vogue TDV8 Java Black
LR021053 bracket
LR017455 strut
LR017461 strap
Hi Dan can I have one please?
Thanks Ash
Post #100865 8th Jan 2012 11:05pm
markdotreed
I fitted this at the weekend along with the updated release button. Was a very easy 20 minute install and in fact the release button was a more 'pain in the 'arris' job to the point I ended up taking the plastic surround off to ensure the clips were located properly.
Installing the ram was a piece of pi$$ and although it doesn't dampen the lower tailgate for the whole movement (The last 10 degrees does seem to fall un-dampened) it's a good inexpensive addition. Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #100877 9th Jan 2012 7:13am
EVOeng
Markdotreed, how did you mount the brackets – screws, bolts, or rivets?
Also, does anyone know if it is normal for the “last 10 degrees... to fall un-dampened”?
Post #100941 9th Jan 2012 4:39pm
Emperor Mong
yes it is normal - falls initially but then does not bang open.
perfect imho - very quick to get it open but no unpleasant noise
Post #100942 9th Jan 2012 4:47pm
markdotreed
I used 6mm self tapping screws and drilled a 4mm hole, although after centre punching the holes I drilled a 2mm hole first.
Very simple, uncomplicated job. If you're unsure of the correct diameter hole to drill, hold the bit up against the screw. The bit should be the same diameter as the screw core which leaves the threads to grip. Regards
Mark
Post #100950 9th Jan 2012 6:01pm
JustinP
The parts arrived today, two new straps, a damper, the bracket and replacement tailgate release button cover - the old buttn cover went missing last time the car was in for a service.
All fitted and working extremely well, the damper adds just enough resistance to let the tailgate drop. I will try and take a video at the weekend and post it to youtube.
I've fitted using self tappers, but I'm a little worried they may pull out, so I'm going to replace with correct torx screws and nuts.
@Mark - have you mounted the damper in the correct orientation with the arrow pointing upwards?
Post #100961 9th Jan 2012 8:19pm
nice job justin.. Thumbs Up ... - .- -.
Post #100962 9th Jan 2012 8:36pm
Googsy
Kinda tempted but if i was going this far I would be looking to fit a motor to the tailgate now that would be sexy Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #100966 9th Jan 2012 9:37pm
JustinP
The photo's not of my car, but mine is just as good Very Happy
Post #100969 9th Jan 2012 10:04pm
Laughing Thumbs Up ... - .- -.
Post #100984 10th Jan 2012 7:45am
markdotreed
I'll admit to putting the damper around the wrong way intitially but it was pretty obvious it was wrong so changed immediately. The only thing I have done slightly differently is the bracket is mounted maybe 10mm further back than shown in the picture. I might re-drill at the weekend and see if it makes a difference. Regards
Mark
Post #100986 10th Jan 2012 8:17am
