![]() | Home > Maintenance & Mods (L322) > Damped opening of lower tailgate |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
The pre-2010MY used to slam down if you let if fall which would risk damaging the cable supports, this just makes it that bit more refined. 2006 Mercedes CLS
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Maybe Dan could sort out some kits? |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Already done on Page 3 of this thread
![]() Gone - Range Rover Supercharged 2006 ![]() |
landyash Member Since: 05 Jan 2012 Location: Nottinghamshire Posts: 72 ![]() ![]() |
Hi Dan can I have one please? Thanks Ash |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
I fitted this at the weekend along with the updated release button. Was a very easy 20 minute install and in fact the release button was a more 'pain in the 'arris' job to the point I ended up taking the plastic surround off to ensure the clips were located properly.
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
Markdotreed, how did you mount the brackets – screws, bolts, or rivets?
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
yes it is normal - falls initially but then does not bang open.
I used 6mm self tapping screws and drilled a 4mm hole, although after centre punching the holes I drilled a 2mm hole first.
The parts arrived today, two new straps, a damper, the bracket and replacement tailgate release button cover - the old buttn cover went missing last time the car was in for a service.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
nice job justin.. |
Kinda tempted but if i was going this far I would be looking to fit a motor to the tailgate now that would be sexy |
The photo's not of my car, but mine is just as good ![]() ![]() Gone - Range Rover Supercharged 2006 ![]() |
I'll admit to putting the damper around the wrong way intitially but it was pretty obvious it was wrong so changed immediately. The only thing I have done slightly differently is the bracket is mounted maybe 10mm further back than shown in the picture. I might re-drill at the weekend and see if it makes a difference. Regards Mark 2009 D4; 1993 Classic 3.9 VSE |
