Home > Maintenance & Mods (L322) > Damped opening of lower tailgate |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
The pre-2010MY used to slam down if you let if fall which would risk damaging the cable supports, this just makes it that bit more refined. 2006 Mercedes CLS
7th Jan 2012 11:42am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Maybe Dan could sort out some kits?
7th Jan 2012 12:24pm |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Already done on Page 3 of this thread
Gone - Range Rover Supercharged 2006 |
7th Jan 2012 1:08pm |
landyash Member Since: 05 Jan 2012 Location: Nottinghamshire Posts: 72 |
Hi Dan can I have one please? Thanks Ash |
8th Jan 2012 11:05pm |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
I fitted this at the weekend along with the updated release button. Was a very easy 20 minute install and in fact the release button was a more 'pain in the 'arris' job to the point I ended up taking the plastic surround off to ensure the clips were located properly.
9th Jan 2012 7:13am |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 224 |
Markdotreed, how did you mount the brackets – screws, bolts, or rivets?
9th Jan 2012 4:39pm |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
yes it is normal - falls initially but then does not bang open.
9th Jan 2012 4:47pm |
I used 6mm self tapping screws and drilled a 4mm hole, although after centre punching the holes I drilled a 2mm hole first.
9th Jan 2012 6:01pm |
The parts arrived today, two new straps, a damper, the bracket and replacement tailgate release button cover - the old buttn cover went missing last time the car was in for a service.
9th Jan 2012 8:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
nice job justin.. ... - .- -.
9th Jan 2012 8:36pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Kinda tempted but if i was going this far I would be looking to fit a motor to the tailgate now that would be sexy Present :2008 TDV8 HSE
9th Jan 2012 9:37pm |
The photo's not of my car, but mine is just as good Gone - Range Rover Supercharged 2006 |
9th Jan 2012 10:04pm |
10th Jan 2012 7:45am |
I'll admit to putting the damper around the wrong way intitially but it was pretty obvious it was wrong so changed immediately. The only thing I have done slightly differently is the bracket is mounted maybe 10mm further back than shown in the picture. I might re-drill at the weekend and see if it makes a difference. Regards Mark 2009 D4; 1993 Classic 3.9 VSE |
10th Jan 2012 8:17am |
