![]() | Home > Maintenance & Mods (L322) > Damped opening of lower tailgate |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
The left one stays the same, the one on the right has a lug on it for the damper to attach to. So yes left is optional, right is different. |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
^^^ perfect thank you 2014 FF Autobiography 5.0 SC
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
Well to all you DIYers that are going the rivnut route make sure you get aluminium rivnuts not stainless steel like what I did |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3660 ![]() ![]() |
^^ D'OH! |
After sweating and cursing for an hour I thought "I'll bet you can get these things in softer metal" I looked, saw and ordered. I knew I was doing something wrong when everyone said 10 minute easy job |
It is with the ally rivnuts |
Just for the record, I blame you |
Please forgive me, I should have kept quite and let you fiddle around with nuts and bolts, but I recon you'd need more than 2 nuts, and your ffrr would end up sounding like a babies rattle |
I did look at fiddling around with nuts and bolts, even removed the tailgate carpet but it looked a bit of a |
By the time you've added the carriage charges that the parts boys want, to the cost of an after sales damper, it's cheaper to buy from L/R |
Job gone |
I got my camera out for some other pics so the following might help some out, I used rivets as suggested by miggit but its important to get aluminium ones my first efforts with stainless steel was ballachingly unsuccessful. I also swapped the bolts for M6 screws as I had plenty and IMO it looks better..
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
My screws have come loose! (after a few months) anyone locally got the rivnut tool that I could borrow? |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 ![]() ![]() ![]() |
I'm in Stafford and have a rivet tool that you could borrow Regards
