Home > Technical (L405) > front knuckle cracking |
Gary M Member Since: 20 Oct 2023 Location: Liverpool Posts: 1 |
My 2015 Range Rover has had this top knuckle failure on the passenger side back in June 2021 as I pulled on to my drive way. I had to replace this my self at my expense including a new drive shaft as it pulled out and stripped the spline.
20th Oct 2023 1:04pm |
NE1 Member Since: 16 Oct 2023 Location: West Sussex Posts: 9 |
There are parts in stock, mine were ordered on Monday or Tuesday this week and being fitted today.
20th Oct 2023 1:12pm |
My safety check flagged a red warning, said 'unable to drive' when i was notified of the cracks, but i wouldn't be happy driving it knowing they were there. |
20th Oct 2023 1:16pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 117 |
Got mine back today. Both sides changed even though only one 'needed' it.
20th Oct 2023 5:33pm |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 155 |
Just had a Mot and re call done on my 16 plate, not sure what happened yet.
20th Oct 2023 5:43pm |
Not a lot to tie them to with the knuckle being removed, besides, it'd get in the way and / or paint damaged. Doesn't make it right, just explaining why they'd remove the calipers. |
20th Oct 2023 5:47pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2490 |
I understood that copper grease isn't suitable for use on aluminium with steel, or is it silver grease that isn't? |
20th Oct 2023 11:46pm |
Neither really, I don't know why they'd do that, it's not on the work instruction. |
21st Oct 2023 6:26am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1772 |
Dissimilar metals. A non metallic grease would be advisable (ceramic based) but copper grease is much cheaper At least they greased it |
21st Oct 2023 9:32am |
Thanks Mikey. |
21st Oct 2023 10:41am |
Looks like this.
21st Oct 2023 11:03am |
waveyd Member Since: 17 Oct 2023 Location: Santa Monica Posts: 9 |
I have entered a case with NHTSA stating that JLR don't have a safety recall in the USA when they do in the UK and Canada, and have given pictures. I recommend everyone that's had this issue do the same, especially is it actually failed on you.
24th Oct 2023 7:35pm |
chugga90 Member Since: 24 Jul 2015 Location: Chilterns Posts: 153 |
Marshall would not know the truth if their lives depend upon it. Hopefully you find someone with a conscience. Or better still go to an independent who cares and get the brakes bled. Will save you a world of pain and further issues! |
25th Oct 2023 5:14am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1488 |
@waveyd:
25th Oct 2023 6:42am |
