Home > Technical (L405) > front knuckle cracking
Page 36 of 50 <123 ... 353637 ... 484950>
NE1
United Kingdom 2016 Range Rover Autobiography SDV8 Scotia Grey
Just got the call from the service dept to confirm my knuckles, yes both of them, will be replaced under the recall, so the VIN range isn't an exact science.
Post #675964 20th Oct 2023 12:37pm
Gary M
United Kingdom 2015 Range Rover Autobiography SDV8 Mariana Black
My 2015 Range Rover has had this top knuckle failure on the passenger side back in June 2021 as I pulled on to my drive way. I had to replace this my self at my expense including a new drive shaft as it pulled out and stripped the spline.
JLR sent me a recall letter early September this year and informed me I could calm my costs back if I had the car checked over at my nearest Land Rover dealership. This took 3,1/2weeks to get booked in they them informed me both top knuckles needed to be replaced even the new one I fitted 18months previously as they were both showing signs of cracking. They also informed me there is a backlog on these parts and we’re not sure when they may get them back in stock.
So i drive home ( carefully) and I await the call
I don’t think it’s right they have let me leave the dealership knowing what could happen.
Does anyone know if theres a collective claim being put together? I would be very interested to know I can’t drive my car or sell it as it stands.
Thanks
Post #675968 20th Oct 2023 1:04pm
NE1
There are parts in stock, mine were ordered on Monday or Tuesday this week and being fitted today.
My car was just out of the VIN range in the V2 Q&A doc, but they have approved the replacement, so hopefully the new ones are better!
Post #675970 20th Oct 2023 1:12pm
NE1
Thanks
My safety check flagged a red warning, said 'unable to drive' when i was notified of the cracks, but i wouldn't be happy driving it knowing they were there.
Post #675971 20th Oct 2023 1:16pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
Got mine back today. Both sides changed even though only one 'needed' it.
Lots of copper grease where the balljoint pin goes into the knuckle.
Seems to drive fine as well.
However the footbrake doesn't work correctly now. The pedal travels a very long way before taking effect. I can't quite understand why - they should have just unbolted the calipers and tied them up out of the way. No need to disturb anything hydraulic, and original discs and pads back on.
So the telephone will be ringing at Marshall Peterborough first thing...
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #675998 20th Oct 2023 5:33pm
zenman63
England 2016 Range Rover Autobiography SDV8 Indus Silver
Just had a Mot and re call done on my 16 plate, not sure what happened yet.
Had a lone car, new Defender 90.
Post #675999 20th Oct 2023 5:43pm
Phoenix
Not a lot to tie them to with the knuckle being removed, besides, it'd get in the way and / or paint damaged. Doesn't make it right, just explaining why they'd remove the calipers.
Post #676002 20th Oct 2023 5:47pm
GraemeS
Australia
I understood that copper grease isn't suitable for use on aluminium with steel, or is it silver grease that isn't?
Post #676017 20th Oct 2023 11:46pm
Phoenix
Neither really, I don't know why they'd do that, it's not on the work instruction.
Post #676025 21st Oct 2023 6:26am
Mikey
Dissimilar metals. A non metallic grease would be advisable (ceramic based) but copper grease is much cheaper
At least they greased it Laughing
Post #676030 21st Oct 2023 9:32am
GraemeS
Australia
Thanks Mikey.
Post #676039 21st Oct 2023 10:41am
ChrisJC
Looks like this.
Chris.
P38 - 4.6V8 HSE
Post #676041 21st Oct 2023 11:03am
waveyd
United States 2014 Range Rover HSE 3.0 SC V6 Loire Blue
USA Recall
I have entered a case with NHTSA stating that JLR don't have a safety recall in the USA when they do in the UK and Canada, and have given pictures. I recommend everyone that's had this issue do the same, especially is it actually failed on you.
This is mine, discovered yesterday
Post #676353 24th Oct 2023 7:35pm
chugga90
Chris.
Marshall would not know the truth if their lives depend upon it. Hopefully you find someone with a conscience. Or better still go to an independent who cares and get the brakes bled. Will save you a world of pain and further issues!
Post #676382 25th Oct 2023 5:14am
Gremlin500
@waveyd:
Interesting picture, looking at that, and given you’re in a “dry state” (geographical, not intoxication! Laughing ) does it slightly pour cold water on the “galvanic corrosion” theories some propose?
Everything in the picture looks almost new, looks more like metal fatigue? Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #676386 25th Oct 2023 6:42am
