![]() | Home > Technical (L405) > front knuckle cracking |
elboss Member Since: 24 Mar 2021 Location: Dubai Posts: 5 ![]() ![]() ![]() |
By The way, This is a single owner bought brand new and never been off-road (Yet !!) |
Sure ... If you need vin # let me know. |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 90 ![]() ![]() |
Very helpful. Thank you for posting. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I wonder if there is a TSB for this. If it was done as regular maintenance then it would be a recall, which should apply to all affected vehicles.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2647 ![]() ![]() |
during regular maintenance, not as regular maintenance. |
Yes, implication being that the dealer just did it foc under direction from JLR, that’s what I meant.. There is nothing that can't be fixed with a hammer😜😜
Yorky man Member Since: 06 Jun 2021 Location: Yorkshire Posts: 2 ![]() ![]() ![]() |
Just read the post regarding the front L/H knuckle failure - I’ve had exactly the same occur recently.
I have had the exact same failure this last week - my 2015 Range Rover has 42K on the clock and full service history.
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
It appears that all the affected vehicles in this thread are 2015, was there a part superseded that particular year?
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
A worrying development for 2015 owners.......... JLR need to act and quick IMHO. 1 maybe unlucky, 2 is definitely bad news. BMW i3 Electric Car
this LR suspension design was common between several models, I’m sure that the L494 used the same parts as the 405. Also the defender and discovery 5 have a very similar setup. Would be interesting to know if there are any similar failures on those as well. There is nothing that can't be fixed with a hammer😜😜
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
blimey, that's scary.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1233 ![]() ![]() ![]() |
Bloody scary failures |
