Home > Technical (L405) > front knuckle cracking |
elboss Member Since: 24 Mar 2021 Location: Dubai Posts: 5 |
By The way, This is a single owner bought brand new and never been off-road (Yet !!) |
24th Mar 2021 7:20pm |
Sure ... If you need vin # let me know. |
25th Mar 2021 1:56pm |
Boatmechanic Member Since: 11 Dec 2019 Location: West coast Posts: 89 |
Very helpful. Thank you for posting. |
28th Mar 2021 2:42pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 |
I wonder if there is a TSB for this. If it was done as regular maintenance then it would be a recall, which should apply to all affected vehicles.
28th Mar 2021 5:09pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2551 |
during regular maintenance, not as regular maintenance. |
28th Mar 2021 8:10pm |
Yes, implication being that the dealer just did it foc under direction from JLR, that’s what I meant.. There is nothing that can't be fixed with a hammer😜😜
28th Mar 2021 9:56pm |
29th Mar 2021 1:25am |
Yorky man Member Since: 06 Jun 2021 Location: Yorkshire Posts: 2 |
Just read the post regarding the front L/H knuckle failure - I’ve had exactly the same occur recently.
6th Jun 2021 8:19am |
I have had the exact same failure this last week - my 2015 Range Rover has 42K on the clock and full service history.
6th Jun 2021 8:37am |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 |
It appears that all the affected vehicles in this thread are 2015, was there a part superseded that particular year?
6th Jun 2021 10:03am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
A worrying development for 2015 owners.......... JLR need to act and quick IMHO. 1 maybe unlucky, 2 is definitely bad news. BMW i3 Electric Car
6th Jun 2021 11:07am |
this LR suspension design was common between several models, I’m sure that the L494 used the same parts as the 405. Also the defender and discovery 5 have a very similar setup. Would be interesting to know if there are any similar failures on those as well. There is nothing that can't be fixed with a hammer😜😜
6th Jun 2021 11:59am |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
blimey, that's scary.
6th Jun 2021 3:53pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 |
Bloody scary failures I definitely agree with crack testing, clean the area up carefully and use the spray crack detector at the least.
6th Jun 2021 5:38pm |
