![]() | Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8436 ![]() ![]() ![]() |
Good luck, keep up the good work.... |
Yes, good luck David... |
That went quick..... |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3162 ![]() ![]() ![]() |
It’s all been pretty straight forward so far.
j3fry Member Since: 23 Dec 2014 Location: Bedfordshire Posts: 59 ![]() ![]() ![]() |
Hi I’m sure I read somewhere that after you release the tensioner pins you should lever the guide to make sure that they have clicked in place and they said quite a bit of force is needed but obviously do your homework on this advice perhaps its to do with the oil pressure |
That’s right.
One step forwards… 2 steps back!
The timing gear is all removed and the filters fished out of the end of the camshafts.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 394 ![]() ![]() ![]() |
Excellent thread David - really enjoying the progress... I'm getting the itch for a 5.0SC now ..... Gavin
Nice shiny delivery from Powerhouse arrived back today |
I‘ve now changed the filters in the camshafts and have refitted the chains, guides, tensioners, etc. The engine is all timed properly, has been spun over and the timing checked so we’re ready for reassembly now.
Won't be long and it will be all back together, top work as usual... Pete
Managed to get a couple of hours on this between last night and tonight.
Wow, that is tight, all downhill now... |
