Home > My Range Rover > Back with another Supercharged! A 5.0 this time! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8180 |
Good luck, keep up the good work.... Pete
5th Sep 2023 2:08pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Yes, good luck David... |
5th Sep 2023 11:18pm |
That went quick..... Pete
6th Sep 2023 11:29pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3066 |
It’s all been pretty straight forward so far.
6th Sep 2023 11:38pm |
j3fry Member Since: 23 Dec 2014 Location: Bedfordshire Posts: 52 |
Hi I’m sure I read somewhere that after you release the tensioner pins you should lever the guide to make sure that they have clicked in place and they said quite a bit of force is needed but obviously do your homework on this advice perhaps its to do with the oil pressure |
7th Sep 2023 9:02pm |
That’s right.
7th Sep 2023 11:57pm |
One step forwards… 2 steps back!
11th Sep 2023 3:36pm |
The timing gear is all removed and the filters fished out of the end of the camshafts.
12th Sep 2023 9:08pm |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 391 |
Excellent thread David - really enjoying the progress... I'm getting the itch for a 5.0SC now ..... Gavin
13th Sep 2023 10:01am |
Nice shiny delivery from Powerhouse arrived back today
13th Sep 2023 11:06pm |
I‘ve now changed the filters in the camshafts and have refitted the chains, guides, tensioners, etc. The engine is all timed properly, has been spun over and the timing checked so we’re ready for reassembly now.
18th Sep 2023 8:53pm |
Won't be long and it will be all back together, top work as usual... Pete
18th Sep 2023 10:05pm |
Managed to get a couple of hours on this between last night and tonight.
20th Sep 2023 8:34pm |
Wow, that is tight, all downhill now... Pete
20th Sep 2023 9:45pm |
