Home > Technical (L322) > 4.4 tdv8 started smoking. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1192 |
Glad to hear the good news Kev fingers crossed that it stays that way |
16th May 2023 9:38am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3231 |
That sounds like good news but how do you explain loosing 3L of oil. I'd remain cautious but optimistic 2012 TDV8 Vogue (L322) |
16th May 2023 9:53am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Roger to the rescue! Family use Clarkes and are very impressed with their service and knowledge! (Less so for Roean btw!)
16th May 2023 9:55am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1214 |
Roean says there isn't a turbo drain mod, they even rang Land Rover Direct who also told them there isn't one!!!! We know more than the so called experts mate. |
16th May 2023 10:07am |
There you go! Has yours had it fitted out of curiosity? Roger will know 👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th May 2023 10:10am |
He couldn't tell me unfortunately. I thought he would. He says there is newish sealant around the lower core plug though.
16th May 2023 10:38am |
Rusty Nuts Member Since: 06 Jan 2021 Location: Shropshire Posts: 54 |
Glad to hear you are making progress with the problem Kevin.
16th May 2023 6:48pm |
Update, the car is still going okay. There is still a puff of smoke when the second turbo hasn't been used in a while but no smoke if used again over the next few miles/days.
4th Jul 2023 10:56am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Green Oval is a great company and know their stuff with this mod, they did mine and it completely resolved the issue. Mine resembled a James Bond movie when overtaking etc if it hadnt stretched it's legs for a few miles, absolutely horrendous. BMW i3 Electric Car
4th Jul 2023 11:15am |
Save yourself a load of cash and risk with the turbo drain mod by simply booting it above 2500rpm regularly when warm Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
4th Jul 2023 11:19am |
Until it dumps enough oil in there for diesel runaway and then youre royally screwed. BMW i3 Electric Car
4th Jul 2023 11:27am |
It's never going to cause a runaway as it's not dumping oil in the intake side. Mine smoked very badly when I first had it but I only get a mild puff now and again when I use the 2nd turbo. Seems to be worse in summer as I've gone a few months in the winter without using the 2nd turbo and not seen smoke. 2012 TDV8 Vogue (L322) |
4th Jul 2023 12:36pm |
Thanks for the replies. Just changed the oil again after draining the mini sump. Made sure the engine was nice and warm and no smoke at the moment.
4th Jul 2023 12:45pm |
Result
4th Jul 2023 12:52pm |
