Home > General > What Did You Do In Your Full Fat Today
Page 206 of 382 <123 ... 205206207 ... 380381382>
Went sand dune bashing and then a spot of fishing at Wilbinga about an hour north of Perth , challenging to say the least with low profile tyres and with DSC off I felt like I had too much power at times but a laugh all the same .
 2008 MY Supercharged
Post #351639 11th Oct 2015 9:32am
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Amazing pics! FFRR looks a bit odd next to the other two Smile
Post #351762 11th Oct 2015 10:35pm
Sql
Funny as I had mine parked next to a Patrol today as well, even took these two quick pics to show how these two show different 4x4 approach. Not quite your background though.
Post #351763 11th Oct 2015 10:42pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
shinchan wrote:
I dismounted the front for begin the install of Osram DRL FOG lights.
be sure to update us 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #352029 13th Oct 2015 1:12pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Steve, put the car in off road height and try the handbrake then in access height... You should find the latter will be rubbish in comparison! Just the way they are I’m afraid & the reason the electric handbrake was developed...
Thanks for that Craig, I shall try the above and see.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #352111 13th Oct 2015 8:44pm
Weegie
Full service. Oils filters etc. Access to a four post lift makes all the difference. Very Happy John
GAP iiD BT-Sold
Post #352213 14th Oct 2015 1:05pm
Ziggy
Australia
Fitted a reversing light..............
Gave the inside a bit of a clean..........
Decided I have to do something with the rear exhaust hanger brackets
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #352364 15th Oct 2015 12:24pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Brake pad warning light came on. Front has had uneven wear on the pads due to sticking calliper on passenger side but certainly not down enough to rub through warning sensor. Any way, new pads and wear sensor wire on front and Bill Oddey warning light still on. Checked rear shoes and not low enough to trigger sensor device. Have ordered new wire for back just in case. Any one know how to turn brake warning light off ?
Also put UV dye in to oil as there is a leak from some where towards the drivers side of the engine, drip collecting on under tray and has certainly splashed around a lot underneath. cleaned off as much as possible and stood underneath with UV torch.... beggar all to see !!! Not a rapid drip so will need to run it a few days and return underneath with light. Recently done rocker gasket on that side yet it's bone dry all around the rocker cover.
Post #352418 15th Oct 2015 7:25pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Took SWMBO and daughter to beach at St Anne's.
After Building Sandcastles, Donkey Rides, and Ice Creams SWMBO was happy.
150 mile round trip, returning 22mpg and never missed a beat.
 Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #353155 19th Oct 2015 5:34pm
SMUTT
Saturday - day out at Manchester Airport
Technical Tours of Nimrod and Concorde - proper Man's Day full of detailed facts and numbers.
 Howard
Post #353156 19th Oct 2015 5:40pm
iKushtyy
England 2007 Range Rover Vogue TDV8 Stornoway Grey
Went on a 600 odd mile round trip up to Bolton to view an XK, whilst I was there I had someone view my Range.. Car didn't miss a beat at all.. Makes me want to keep it..
Post #353580 22nd Oct 2015 10:13am
iKushtyy
Then today I get a offside front airbag failure.. Crying or Very sad
At least it didn't happen in Manchester I suppose Confused ..
Post #353630 22nd Oct 2015 3:50pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
iKushtyy - your first post had me reminiscing and thinking of returning to a ff, your second post changed my mind again !!! There is no doubt i will get another at some point but just wouldn't be suitable for me at the moment Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #353699 22nd Oct 2015 8:28pm
Numb
Scotland 2005 Range Rover Vogue Td6 Java Black
Changed diff oils and coolant. Easy with no dramas Very Happy .
Post #353736 23rd Oct 2015 12:18am
SMUTT
Thanks to @Haylands advice.,.. 80deg kit fitted - No hammers were used in the fitting. Laughing lower temp reduce stress on engine (sounds more relaxed) and hopefully plastic components will live longer. Also reduced temp hopefully less pressure and less leaks.
of this component.
New Rad Top Hose PCH001110 - cured leak near Alternator Very Happy
New Stubby heater manifold connector fitted - the one right at rear of engine - quite comfortable working there now after changing the PCV. This was basically a pre-emptive strike against failure as they often go. JHC000081
Fitted New GearBox OIL COOLER THERMOSTAT (OEM BEHR) PBM000010
& New GearBox OIL COOLER MOUNTING PLATE (Genuine LandRover) PCU000140
Fortunately mine were not brittle so keeping old one as spares.
New Antifreeze for our expected cold winter.
All in all a good day on pre-emptive strike on cooling system leaks
Just me, cups of tea and biscuits. SWMBO made me lunch but was left to tinker away in peace.
What more could a man want. Cool
. Howard
Post #354814 31st Oct 2015 5:58pm
