Home > General > What Did You Do In Your Full Fat Today |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Went sand dune bashing and then a spot of fishing at Wilbinga about an hour north of Perth , challenging to say the least with low profile tyres and with DSC off I felt like I had too much power at times but a laugh all the same .
11th Oct 2015 8:32am |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 251 |
Amazing pics! FFRR looks a bit odd next to the other two |
11th Oct 2015 9:35pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 |
be sure to update us 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
13th Oct 2015 12:12pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Steve, put the car in off road height and try the handbrake then in access height... You should find the latter will be rubbish in comparison! Just the way they are I’m afraid & the reason the electric handbrake was developed...
13th Oct 2015 7:44pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Full service. Oils filters etc. Access to a four post lift makes all the difference. John
14th Oct 2015 12:05pm |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
Fitted a reversing light..............
15th Oct 2015 11:24am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Brake pad warning light came on. Front has had uneven wear on the pads due to sticking calliper on passenger side but certainly not down enough to rub through warning sensor. Any way, new pads and wear sensor wire on front and Bill Oddey warning light still on. Checked rear shoes and not low enough to trigger sensor device. Have ordered new wire for back just in case. Any one know how to turn brake warning light off ?
15th Oct 2015 6:25pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Took SWMBO and daughter to beach at St Anne's.
19th Oct 2015 4:34pm |
Saturday - day out at Manchester Airport
19th Oct 2015 4:40pm |
iKushtyy Member Since: 19 Apr 2015 Location: London Posts: 94 |
Went on a 600 odd mile round trip up to Bolton to view an XK, whilst I was there I had someone view my Range.. Car didn't miss a beat at all.. Makes me want to keep it.. |
22nd Oct 2015 9:13am |
Then today I get a offside front airbag failure..
22nd Oct 2015 2:50pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
iKushtyy - your first post had me reminiscing and thinking of returning to a ff, your second post changed my mind again !!! There is no doubt i will get another at some point but just wouldn't be suitable for me at the moment Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
22nd Oct 2015 7:28pm |
Numb Member Since: 29 Dec 2013 Location: West Coast Posts: 35 |
Changed diff oils and coolant. Easy with no dramas . |
22nd Oct 2015 11:18pm |
Thanks to @Haylands advice.,.. 80deg kit fitted - No hammers were used in the fitting. lower temp reduce stress on engine (sounds more relaxed) and hopefully plastic components will live longer. Also reduced temp hopefully less pressure and less leaks.
31st Oct 2015 4:58pm |
