![]() | Home > General > What Did You Do In Your Full Fat Today |
Installed new lower control arm, greased bolts after reinstalling new ones and one for height sensor, then worked on a weird foglight issue. One bulb had gone and then the other didn't work...
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Brake pipes sorted at hunters in Derby
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Drove back to Manchester after a weeks holiday in Bluestone National Park, South Wales - didn't fancy spending hours in queues on the motorway network on a Friday night so it was 200 miles of hilly A/B roads through the heart of Wales, fully loaded with Mrs, two kids and enough stuff to equip a small army for a prolonged campaign!
Numb Member Since: 29 Dec 2013 Location: West Coast Posts: 35 ![]() ![]() ![]() |
Drove home after recon box fitted. Very satisfied. |
Went long way home because it felt gooood. |
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 252 ![]() ![]() ![]() |
Was chauffered around by my girlfriend, it is nice to be a passenger in a FFRR!
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
nice shorts! |
Makes the interior of a fatty look that much more classy IMHO |
Thanks! |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Ok - so maybe not today (last Wednesday actually) but....
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Fitted new handbrake cables (thanks Dan), just finished. Handbrake doesn't seem much better. Will see what it is like tomorrow after a run.
Martyn Member Since: 10 Mar 2013 Location: Poole Posts: 65 ![]() ![]() |
Gearbox oil change, along with a new pan/filter, rear differential oil change and new plugs, oil and filters. Not bad for an afternoons work on the driveway. 2013 FFRR Vogue SE |
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 109 ![]() ![]() |
I dismounted the front for begin the install of Osram DRL FOG lights.
Steve, put the car in off road height and try the handbrke then in access height... You should find the latter will be rubbish in comparison! Just the way they are I’m afraid & the reason the electric handbrake was developed... |
