Home > Technical (L322) > Where did that cloud of smoke come from?
Page 6 of 13 <123 ... 567 ... 111213>
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Dennis I had a similar code P-2459-65 (2a) and then (6c) variant with same words before mine was fixed by the thermostat. CHeck your wiring underneath perhaps for either pinching/fraying or loose connection?
Post #578126 2nd Jan 2021 2:32pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
H Dolphinboy I have a new coolant sensor on order as this was my next port of call going on your earlier recommendation. I will have a good look at the wiring whilst replacing and see what I find. On a positive note I did manage to fix the windscreen wiper, it had popped off the assembly arm and just needed to be clipped back in place 2011 TDV8 Vogue SE
Post #578162 2nd Jan 2021 7:12pm
Dolphinboy
Dennis, am thinking at all the long shots now. Take them with a pinch of salt.
it may be something like inefficient diesel injection pressure into the exhaust not giving a high enough temp to fully clean.
It may be a low exhaust pressure, hole in exhaust? (Have you had a pressure test on the DPF done?)
this from a Ford engine specialist:
Potential causes for this code (P-2458) to set are:
Insufficient diesel exhaust fluid/Incorrect diesel exhaust fluid
Shorted or open wiring to the DPF injection system
Defective PCM or a PCM programming error
Defective DPF pressure sensor Faulty exhaust pressure sensor
Read more at: https://www.obd-codes.com/p2458
Post #578169 2nd Jan 2021 8:05pm
GGDR
What's this reading? Ideally under driving conditions, not heavy throttle ?
Also at idle ?
If at idle it's 0.7 to 0.8 v that's normal.
Under load should be around 1.0v
Otherwise:
For some reason the regeneration didn't like the conditions. So worth just checking the basics:
-Were you using cruise control? Regens much prefer cruise
-Did your fuel fall below 1/4 tank while regenning?
. Cheers, Greg
Post #578173 2nd Jan 2021 8:19pm
dennij
Hi Dolphinboy, any options are currently considered so any pointers are always appreciated Thumbs Up
GGDR - Voltages are all good and within the regions you’ve quoted. Car was sat at cruise doing 65MPH on a quiet motorway with a full tank of fuel. It’s odd that by now I should have the amber DPF message but currently this isn’t showing. The car is asking for a regeneration to be performed as I can see the demanded regeneration count go up but not excessively. Oil dilution is also below 7. 2011 TDV8 Vogue SE
Post #578234 3rd Jan 2021 12:51pm
DrRob
Let’s work together on this. Family friends 2011 4.4 tdv8
Amber DPF warnings - regular and clearing even after 40miles Big Cry
Error code:
P2458-66 DPF regen
Live values:
Soot too high= nearly at RED (27)
Oil dilution = nearly at MAX (7)
Voltage = normal at idle
Number of successful regens seems low for 89K mile car (mine has 190 regens and around 103K miles) Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588723 24th Mar 2021 3:18pm
dennij
Sounds like a plan to me, happy to provide any input I can from my own tests carried out so far. 2011 TDV8 Vogue SE
Post #588729 24th Mar 2021 3:42pm
dennij
This is the current state of my DPF, sadly you cannot see the rear end due to the design which is probably where most of the ash blockage would be. To be honest I was surprised it looked as clean as this as my reading is now in the red, although you can see a thick deposit at the lower edge.
These were the last readings I took from the IID tool when checking the coolant temperature. Exhaust gas temps are high as it was supposed to be carrying out a regeneration at the time but the soot level never changed.
 2011 TDV8 Vogue SE
Post #588732 24th Mar 2021 3:56pm
DrRob
Re: update - DPf over regen
Dolphinboy wrote:
@Dennij.
Well we may have found the problem.
The Thermostat housing was damaged (possibly when another dealer fitted a new inlet manifold in Feb) and reading high which meant that the engine was running cold and therefore not able to sustain the high temps to keep a regen going. The thermostat was giving a false reading of 105 degrees (should be 98 ) and keeping open and initiating the Fans (I had noticed the fans came on very quickly and often but was told by another LR indie "oh they all do that" Evil or Very Mad). The engine Temp sensor was also kaput and reading higher than the real temp. This meant the the ECU was trying to initiate regens and not able to due to low temps.
These sensors have been changed along with the oil cooler (was leaking into coolant) and it now appears to be working ok. The LR indie initially went for a drive for over an hour and a half to get the temps high enough (high revs and big load going uphill) and got it to regen correctly, monitoring the temps on a laptop as he drove. that's how he identified the poss cause.
Did he (Steve Norman?) change the entire thermostat housing or just the engine coolant temperature sensor (ECT) on the front of the housing?? Is there more than one sensor as you use the plural "sensors"? Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588735 24th Mar 2021 4:23pm
DrRob
dennij wrote:
Why have you got EGT in Volts and not Temperature? Temperature is the normal field we choose I thought? Whistle
ECT Sensor in Volts = is this a normal figure (0.357) at 92 'C? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588737 24th Mar 2021 4:29pm
dennij
Laughing Well spotted, I hadn't even noticed as normally I have the temps. I was probably working through the diagnostics sheet in the WM and checking voltage was within the range during the regen. What I have noticed though is that when the regen takes place, the time scales don't add up as I would see the temp drop from 600c + after a few minutes and it would hover around the 400 - 550 mark for a while, then back to 600 plus and so on until it had had enough and would appear to want to have a rest and the temps would drop back down again. Some time later off it would go again so this may be worth checking on your friends RR too. 2011 TDV8 Vogue SE
Post #588738 24th Mar 2021 4:41pm
dennij
Normally I have temps
 2011 TDV8 Vogue SE
Post #588746 24th Mar 2021 5:13pm
Dolphinboy
@dr Rob.
He changed the thermostat, the housing and the engine temp sensor (LR Part no. LR044930)
Post #588759 24th Mar 2021 6:10pm
DrRob
OK, thanks. Is yours now running ok Dolphinboy? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588760 24th Mar 2021 6:30pm
Dolphinboy
Yep Rob. Faultless. Steve just said he worked down through all the possible options until he hit the one that made the difference.
Post #588768 24th Mar 2021 7:29pm
