![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Air flow restriction can be on the output too.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
A minor update on my flakey seat base heater. I've been trying again to remove it from under the seat and then I found an image of the part
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3818 ![]() ![]() ![]() |
Greg,
Hi Mike, yes same - empty data pages for those items. The picture you posted is all I have too.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
mike/greg, change the file extensions to 'pdf'... |
WOW thanks Stan!
Greg,
PM'd you Mike
Thanks to Stan & Greg. |
Hi guys,
Cheers John, I'll give that a try.
This is worth a read
My theory is, that the peltier is actually working in your case, and heating up.
jmhinkle Member Since: 11 Sep 2018 Location: Portland, OR Posts: 2 ![]() ![]() ![]() |
Ran across this while looking up problems with my seats. With 157k miles I expect the filters are filthy. The passenger seat still works, but the drivers doesn't seem to heat or cool. I expect it needs a new unit. I'll start with filter first though. A lot of the Ford owners are buying the RR filters because it still has the filter media in it. I'm actually ordering the Ford FS-106 for better airflow. Found the FS for a little cheaper than the RR filter. Does anyone know if the F150 fan unit is a direct replacement for the RR unit if it is bad? |
