Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
jmhinkle Member Since: 11 Sep 2018 Location: Portland, OR Posts: 2 |
Is that for the seat back or bottom unit? Which Ford part number did you get? I've come up with a few different ones and in pictures none seem to be an exact fit for the pictures of the RR unit. |
11th Sep 2018 7:59am |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
The fans and peltiers are the same parts for both seat base and back, its just the plastic ducting that differs.
11th Sep 2018 12:56pm |
SLAMG Member Since: 11 Dec 2017 Location: Vancouver Posts: 4 |
hey there, did anyone end up getting info back on the ford parts? Its getting cold up here in Canada and my heated seats no longer work |
19th Nov 2018 6:18am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
I bought the Mustang unit, it's a replacement for the base unit.
19th Nov 2018 7:11am |
This one:
19th Nov 2018 7:14am |
oh looks close. will you attempt to install it? |
20th Nov 2018 4:02am |
yes it's on my list.
20th Nov 2018 7:48am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
It`s a bit of a struggle to do it in place I did mine, a lot of satisfaction on completion and a nice warm bum now. |
20th Nov 2018 8:54am |
Did you buy the ford part as well?
20th Nov 2018 3:38pm |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 |
Well got a bit more testing done today , pass seat works fine , hot and cold , base and back , warms up quite quickly , drivers seat cools fine , put it on heat and shuts down after a few seconds , reset everything and run on heat with just back , I can hear fan running with my ear against seat but very little heat (compared to pass side ) , looks like it might be expensive , seems like base unit is causing the shut down but the seat back is producing very little heat . |
20th Nov 2018 4:45pm |
Hi, Slamg at the time I did not know about the Ford part so replaced with the LR part @£243 I have a small ratchet with a bit that fitted, in the end, to get the cover off against the centre console that the part that is a PITA, |
20th Nov 2018 4:59pm |
SLAMG the ebay link I posted is a Ford unit. For a Mustang I think.
20th Nov 2018 6:23pm |
matthews - your description issame as mine is doing.
20th Nov 2018 6:36pm |
That's what I find , back will heat but not very hot compared to pass seat as long as I turn base off immediately , leave base on and it all shuts down , going to loosen seat and check all connectors today if I get chance . |
21st Nov 2018 10:53am |
