Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Air flow restriction can be on the output too.
3rd Apr 2018 9:14pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3543 |
A minor update on my flakey seat base heater. I've been trying again to remove it from under the seat and then I found an image of the part
9th Apr 2018 11:41am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3768 |
Greg,
9th Apr 2018 1:30pm |
Hi Mike, yes same - empty data pages for those items. The picture you posted is all I have too.
9th Apr 2018 2:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35312 |
mike/greg, change the file extensions to 'pdf'... ... - .- -.
9th Apr 2018 2:36pm |
WOW thanks Stan!
9th Apr 2018 2:50pm |
Greg,
9th Apr 2018 3:07pm |
PM'd you Mike
9th Apr 2018 3:17pm |
Thanks to Stan & Greg. G reg 2.5VM Vogue Portofino red 1991- 1999
9th Apr 2018 3:49pm |
Hi guys,
11th Apr 2018 9:55pm |
Cheers John, I'll give that a try.
12th Apr 2018 11:44am |
This is worth a read
14th Jul 2018 10:00pm |
My theory is, that the peltier is actually working in your case, and heating up.
15th Jul 2018 4:57pm |
jmhinkle Member Since: 11 Sep 2018 Location: Portland, OR Posts: 2 |
Ran across this while looking up problems with my seats. With 157k miles I expect the filters are filthy. The passenger seat still works, but the drivers doesn't seem to heat or cool. I expect it needs a new unit. I'll start with filter first though. A lot of the Ford owners are buying the RR filters because it still has the filter media in it. I'm actually ordering the Ford FS-106 for better airflow. Found the FS for a little cheaper than the RR filter. Does anyone know if the F150 fan unit is a direct replacement for the RR unit if it is bad? |
11th Sep 2018 7:32am |
