Home > Technical (L322) > Delayed Air Con
Page 2 of 8 <12345678>
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Wow. 3.6 hours seems a lot. I assume it's a headache to get to it? 2010 4.4 TDV8 Vogue SE
Post #481969 27th Jun 2018 11:37am
GraemeS
Australia
I suspect that the LR procedures require the compressor be removed but even then 3.6 hours is a lot. I recall that the one that was done without removing the compressor was done from underneath the vehicle. I might have a look at mine's compressor to see what access to the valve might be like.
Post #481978 27th Jun 2018 12:52pm
GraemeS
Australia
https://www.aulro.com/afvb/l322-range-rove...put-2.html
If paying someone to R&R the compressor to replace a sticky valve then perhaps better off in the long term having a new, later version compressor fitted.
Post #481982 27th Jun 2018 1:15pm
kooky_guy
So, just to confirm, these sticky valves are actually in the compressor or is it a separate unit?
I'm still trying to work out the best place to get mine looked at - an aircon specialist or another indy.
It's really annoying. Mine usually works well after a couple of minutes but only if the engine is completely cold. A warm start always results in no air con which is rather annoying in this heat. 2010 4.4 TDV8 Vogue SE
Post #483065 10th Jul 2018 7:48am
GraemeS
Australia
Yes, the valve is in the rear of the compressor.
Post #483067 10th Jul 2018 8:05am
nino_nino
kooky_guy,
this is our compresor:
this is where valve is:
and this is the valve:
it appears that valve is on the bottom facing engine block so most likely it is compresor out job. Crying or Very sad
Nino,
Post #483076 10th Jul 2018 9:50am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Not driven mine for 3 months and it's showing exactly these symptoms. I'll see if a bit more usage clears the sticky flaps. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #483079 10th Jul 2018 10:47am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Thumbs Up Thumbs Up Unnecessary quote removed
Thumbs Up Thumbs Up 2012 TDV8 Vogue SE 4.4
Post #483125 10th Jul 2018 7:46pm
kooky_guy
Thanks Nino. Very helpful pictures! 2010 4.4 TDV8 Vogue SE
Post #483159 11th Jul 2018 7:51am
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Are there any details of how to actually change this ?
How is it held in ?
I assume I dont stand a chance of getting this done by LR outside of warranty, so tempted to buy the part and give it a go myself.
If I do, I will post back how I get on. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #483201 11th Jul 2018 2:12pm
nino_nino
John, search youtube for senden compressor valve removal, valve is held in place by snap ring -
and if you do go and change valve - take lots of pictures pls.
Nino
Post #483210 11th Jul 2018 4:00pm
John w
I took a look at my compressor earlier, and was starting to think my compressor might be fecked.
This is because it appears as if the clutch never disengages, even with a/c off and ignition off.
Having done a bunch of searching and reading, I discovered these compressors don't have a conventional magnetic clutch.
Here is a link to explain how they work, and what the valve does:
This helps to explain why it may partially work, but not fully cool.
I also tried to see what access is like.
To say it's a b@stard to get to would be a bit of an understatement.
I think it may be possible to get to from the bottom, but needs the serpentine belt removing, and the compressor unbolting from the block.
I will have a better look at the weekend. Too many toys, not enough time
Post #483242 11th Jul 2018 11:28pm
GraemeS
Australia
How is it held in ?
LTB00693 documents the procedure but the only one that I can find is in either Japanese or Chinese. IIRC from when I saw the English version, the refrigerant has to be drained/collected before the valve is removed which would appear to mostly prevent it being a DIY task.
Post #483262 12th Jul 2018 10:52am
kooky_guy
I've just had my compressor replaced and it's completely fixed the issue, thank goodness.
It was suggested by the Indy that since it was such a big job to remove the compressor in any case, I would be better off paying a bit extra to replace it rather than just the valve as that would give me a 2 years parts and labour warranty. He suggested that just replacing the valve might not be a long lasting solution...
Weirdly, it seems to be running much better since it was replaced too.
But it was much more expensive than I expected. 2010 4.4 TDV8 Vogue SE
Post #484691 30th Jul 2018 8:52am
John w
Glad to hear its fixed Thumbs Up
Oddly mine continues to sort-of work. It also gets much cooler if I go round tight right handers, so I find myself searching for round abouts Laughing
I have a picture on my phone of the compressor from underneath the car (will try to upload it). It looks like a b@stard to get to, but I can see the solenoid. I think it could be possible to get it out without having to fully remove the compressor.
I am holding off at present until I have identified my oil leak, so I can deal with both together.
I also need to figure out what the other pipes are around it, so I know what to remove to gain access.
Incidentally, I plugged my OBD tool in last week and was able to monitor the various settings. It is clear to see the compressor is making pressure, and when you switch off the A/C the pressure drops away.
I have a permanent failure on the ambient air temp sensor, which I found on the near side behind the radiator (seen other threads on this, its the same as a bmw part, and only affects things when on auto apparently). Too many toys, not enough time
Post #484714 30th Jul 2018 1:44pm
