Home > Technical (L322) > Delayed Air Con
Page 8 of 8 <12345678
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
Seeing as I seem to have the problem that the aircon on the (LH) driver's side blows a little cold air and on the RH side blows warm air only I searched and found this topic.
Mine's a late 2007 model though so I was wondering if it might be something else ?
I read something about a blend door in the air circulation system ?
Any help is appreciated as it's no fun driving that bus around with the feeling that the heater is on with 26 degrees outside !
Cheers, Ard
Post #692554 13th May 2024 6:53pm
mjdronfield
I think that will prob be different. This issue is no air con at all, then everything ok.
I too think it might be something to do with blend motors, but I’m no expert.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #692555 13th May 2024 7:00pm
Dutchgit
Thanks for that !!
Luckily it was just the system needed a recharge !
Had it done at the local Bosch garage and they had time to do it today.
Ooh it's lovely and cool again ! In fact, better than it has been in our time of ownership since September last year.
Post #692653 14th May 2024 7:09pm
mjdronfield
Nice one. Glad you got it sorted.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #692664 14th May 2024 8:22pm
TDV8 Paul
Glad this was resurrected As my fairly new to me 09 (2010 MY) has been doing this and it really threw me as to why as I never had that issue in my 07. I’ll try a regas to make sure that is where it should be and if not, I guess I’ll be replacing the compressor too! 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #692667 14th May 2024 9:06pm
Dutchgit
So was I ! It was about 120 or I think the wifey said but she got a loaner car ("her comment: "We'll definitely not buy a Renault!" Laughing ) and (so far) we didn't have to fork out for a new compressor !! Bow down (Not to mention spending more time laying on the drive)
I hope it'll solve your issue as well TDV8 Paul !
Cheers, Ard
Post #692742 15th May 2024 7:14pm
TDV8 Paul
Thank you Dutchgit, my fingers are crossed when I get round to it at some point! 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #692746 15th May 2024 8:32pm
Dutchgit
Make sure your aircon is turned off just in case the oil runs out of it completely.
(Just my thoughts, don't know if it will harm the system when it's low on anything.
Cheers, Ard
Post #692867 17th May 2024 5:56pm
miketrike
United Kingdom 2011 Range Rover SE TDV8 Baltic Blue
the search term is sanden not senden
nino_nino wrote:
John, search youtube for senden compressor valve removal, valve is held in place by snap ring -
and if you do go and change valve - take lots of pictures pls.
Nino
Post #694881 22nd Jun 2024 9:17am
pcourtney
Interesting, from cross referencing the part no LR056364
It seems a lot of JLR motors also use the L322 AC compressor, and the price is almost half Smile
8W8319D629AC
C2D38695
CPLA19D629BE
LR035761
LR056364
LR057692
LR068128
LR086043
c2d45382
c2d56291
Post #697113 29th Jul 2024 10:44pm
tvrforever
So my 2012 L322 Westminster has started doing a couple of odd things re the AC:
1) Taking 5-10 mins to get cool, starts blowing firmly but air is ambient temp, then after 5-10 mins there is a noticeable step point over a few seconds where the temp reduces. But it never actually gets cold.
2) Whilst the air gets cool, it never gets cold; certainly never feel cold air from the AC regardless of time, cool yes but never cold
It was regassed earlier in the year so I guess it's new value or compressor time, unless anyone has any other suggestions?
Post #698249 17th Aug 2024 2:50pm
mjdronfield
Sounds like the valve issue, though mine works nice and cold once it’s all got itself together…. So maybe you have 2 issues, but I think if you change the valve/compressor it will have to be re gassed anyway.
Mine normally comes on ok if the revs build whilst driving.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #698258 17th Aug 2024 5:00pm
JayGee
Sounds like the compressor to me and similar to my symptoms. Depending on your budget you may want to get a few other items replaced like the belt and tensioners, waterpump, alternator etc as a lot of the labour involves removing the fan and shroud to get at it and these other items are then also replaceable. 2012 TDV8 Vogue (L322)
Post #698259 17th Aug 2024 5:06pm
