Home > Technical (L322) > Delayed Air Con |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Wow. 3.6 hours seems a lot. I assume it's a headache to get to it? 2010 4.4 TDV8 Vogue SE |
27th Jun 2018 10:37am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2492 |
https://www.aulro.com/afvb/l322-range-rove...put-2.html
27th Jun 2018 12:15pm |
So, just to confirm, these sticky valves are actually in the compressor or is it a separate unit?
10th Jul 2018 6:48am |
Yes, the valve is in the rear of the compressor. |
10th Jul 2018 7:05am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
kooky_guy,
10th Jul 2018 8:50am |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
Not driven mine for 3 months and it's showing exactly these symptoms. I'll see if a bit more usage clears the sticky flaps. 2017 5.0 Autobiography Supercharged
10th Jul 2018 9:47am |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Unnecessary quote removed
10th Jul 2018 6:46pm |
Thanks Nino. Very helpful pictures! 2010 4.4 TDV8 Vogue SE |
11th Jul 2018 6:51am |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Are there any details of how to actually change this ?
11th Jul 2018 1:12pm |
John, search youtube for senden compressor valve removal, valve is held in place by snap ring -
11th Jul 2018 3:00pm |
I took a look at my compressor earlier, and was starting to think my compressor might be fecked.
11th Jul 2018 10:28pm |
LTB00693 documents the procedure but the only one that I can find is in either Japanese or Chinese. IIRC from when I saw the English version, the refrigerant has to be drained/collected before the valve is removed which would appear to mostly prevent it being a DIY task. |
12th Jul 2018 9:52am |
I've just had my compressor replaced and it's completely fixed the issue, thank goodness.
30th Jul 2018 7:52am |
Glad to hear its fixed
30th Jul 2018 12:44pm |
